01-11-2021, 08:45 AM
[SOLVED] What tool do I use to remove this screw?
This particular screw is used in many areas of our coach, most extensively on the door latch and access cover on the cargo bay doors. I may just be missing something easy, which is highly likely, but I have tried every torx bit, allen bit, etc. in my tool chest and nothing fits. Is it a special bit and, if so, would someone point me in the right direction to acquire one?
I feel a bit stupid even asking, but I also have similar screws on my cargo trailer and had to have a small repair done on the rear door. The shop called and said they could not get the screws removed due to this same issue.
Joe & Cynthia
2021 Dynaquest XL 3801 TS Cindy 'B'
2021 Jeep Wrangler Unlimited Rubicon Diesel
“Breathe in, Breathe out, Move on”
01-11-2021, 08:50 AM
Attachment 245809
That’s a pop rivet. You have to drill those out and re-rivet or replace with a screw. I have a rivet gun and an assortment of rivets I use. That looks like a 3/16 rivet. Use a 3/16 drill bit to drill it out.
2008 Dynaquest 340xl
Bill and Carol
Retired mechanic
US Army Veteran 🇺🇸
Previous coach 2017 Isata 3RW
Also,3 Diesel pushers, 1Bvan, 2 class Cs
01-11-2021, 08:56 AM
That's not a pop-rivet... it is a TORX head screw.
It could be a HeadLok brand that have finer splines.
Here are some examples...
There are bits in various sizes that will fit them just in the same fashion as a Phillips head screw.
If you had a shop that couldn't remove them you need to find a different shop!
Here is what a TORX bit looks like...
Some TORX head screws are anti-tamper (can't tell if yours are from the photo) and have a raised tit inside the head. You'll need a TORX bit with the appropriate hollow center for those.
01-11-2021, 09:00 AM
I figured it out. It is not a pop rivet or a Torx screw, it’s an 8 spline #2 screw that requires a special bit. Not sure the advantage of using these vs. a normal, more readily available Torx screw, but they are there and I must remove some to gain access to the remote lock module. So, Amazon to the rescue once again.
VEGA Double Square #2 Bits. Professional Grade 1/4" Hex Shank #2 Double Square 2" Power Bits. 150DS02A-3 (Pack of 3)
Joe & Cynthia
01-11-2021, 09:07 AM
Oops. After a closer look it’s not a rivet. Sorry. I can’t tell for sure from the picture if it’s a torx or a square head. That looked like a latch cover on a bay door and mine are riveted. Sorry about the confusion.
Bill and Carol
Retired mechanic
US Army Veteran 🇺🇸
01-11-2021, 09:11 AM
See the post just before yours.
01-11-2021, 09:17 AM
Cannot judge size well with the picture.
Square bit screwdrivers if the right size will work. Got to be careful. The special 8 point bit would be better.
01-11-2021, 09:19 AM
Torx bits have six points. The screw in the photo requires a bit with 8 points. I don’t know for sure, but the HeadLok bit shown in post #3 could be the right tool.
If you cannot locate the correct 8 point point bit, I have found I can manage to remove and install these screws successfully with a square bit. The 4 points of the square bit, if it’s the right size, can line up and grab every other point of the 8 point screw.
(Looks like I was typing about the square bit at the same time as tomkatb)
2020 Sunseeker 2440DS on 2019 Ford E-450, Trekker cap, Topaz paint
01-11-2021, 09:24 AM
I saw that post, I just wanted to apologize for posting misinformation.
Bill and Carol
Retired mechanic
US Army Veteran 🇺🇸
01-11-2021, 10:09 AM
Trailer Park Supervisor
Why in the hell do some mfr's insist on using uncommon fasteners???? This is the kind of thing that takes any fun (not that it's fun to begin with)out of a job, being flummoxed by not having a special tool to remove a fastener. Good grief.
Yes, I drink the water!
01-11-2021, 10:15 AM
I think they are in cahoots with the tool manufactures.
Bill and Carol
Retired mechanic
US Army Veteran 🇺🇸
01-11-2021, 10:16 AM
Its actually a double square drive. A Torx bit will work, but you take a chance of stripping it out. The double square drive is a very common screw head used in the trailer, specifically utility trailer, industry. You can use a square drive and it will work very well. They do make a double square drive bit, but very hard to find. In all the trailer work I have done, I have just used a square drive on it.
2017 Ram 2500 CTD
2019 Shockwave T25RQMX
*Retired - 2018 F150 EcoBoost MaxTow
RVing - Friends and Marshmellows getting toasted at the same time -
01-11-2021, 10:18 AM
X2
Bill and Carol
Retired mechanic
US Army Veteran 🇺🇸
01-11-2021, 11:48 AM
Square bit.
01-11-2021, 12:02 PM
Old Ram Guy
I agree with 5Picker, you still should find another shop. As mentioned, these are fairly common fasteners in the camper industry.
Marty, Jenice and DD
2019 Entegra Odyssey 29V
01-11-2021, 12:33 PM
It looks like an 8 point, you use a square bit to engage 4 of the eight. Don't feel dumb, I called my dealer the first time thinking I needed an 8 point bit.
Northern Indiana
2018 Salem Cruise Lite M-241QBXL
2018 GMC Canyon Denali
01-11-2021, 01:22 PM
Amazon has the bits
Amazon has listings for square bits, and double square bits.
01-11-2021, 01:27 PM
2014 XLR 27HFS
When FR put together my trailer, they used square bit screws on almost everything. When I find something other than the square bit or phillips, I don't put that screw back in.
Dave & Audrey
01-11-2021, 01:30 PM
Same here!
01-11-2021, 01:35 PM
It amazes me that a shop would call and say they can’t remove a screw.
Per the post #17 above, here is an Amazon listing:
https://www.amazon.com/VEGA-Double-S...0390002&sr=8-4
