Originally Posted by Barch
My new ISATA 3 FW is fairly quiet except when first starting out. When pulling out of a campground or parking lot or service station there is a loud banging noise that seems to come from the left side of the coach directly behind the driver. It is like something banging on the slide. It is worse with any rocking motion and tends to disappear at highway speeds. I have searched and searched for the source and cannot find it. Any ideas?
That is most likely the Helwig sway bar, the mounting bolts might need to be re-torqued.
Instruction attached on the install. When you rock, either the slotted holes in the mounting brackets are sliding or maybe there is slop in the clevis.
