07-19-2024, 10:16 AM
Starlink Cable Through Bottom Seal of Compartment?
I am thinking of placing the Starlink router in the front right compartment of my 2022 Isata 5 since there is power there. Is there any problem running the cable though the bottom of the compartment door? Will that compress the seal so water will come in?
07-19-2024, 11:27 AM
I was thinking about the same, but worried about the compartment trapping heat and over heating their router
07-19-2024, 11:37 AM
I don’t think you need to worry about heat. I put mine in the basement of my 5th wheel. Here are the specs..
STARLINK WIFI ROUTER
Wi-Fi Technology IEEE 802.11a/b/g/n/ac standards
Generation Wi-Fi 5
Radio Dual Band - 3 x 3 MIMO
Security WPA2
Environmental Rating IP54, configured for indoor use
Coverage Up to 185m² (2000sqft)
Operating Temperature -30°C to 50°C (-22°F to 122°F)
2016 Siverback 33IK, Towed 60K+ mile
07-19-2024, 11:44 AM
Over time, you will breakdown the cable if you close the door on it enough. You will put an indentation in the seal but there is shielding in addition to the wiring inside the Dish cable. If you open and close the door enough of times, you are bound to weaken the cable and possible create connectivity and / or performance issues.
I have been using Starlink for over two years. On my Super C I ran the cable through the roof and mounted it on the ladder with a FlagPole Buddy Mount and I had enough cable left to move the Dish around the coach if the ladder mount did not have a clear line of sight.
I am currently installing it on my Isata 3 Freedom Edition. I am using this waterproof connector.
https://www.amazon.com/dp/B0BMFBJTTG...roduct_details
2024 Dynamax Isata 3 24FWSFX Freedom Edition
Previous Coaches:
2020 Thor Magnitude SV34
2018 Thor Outlaw 29H
07-19-2024, 03:16 PM
Can you run it through an access panel on the side of the compartment? Our Europa had an access panel already but they are easy to install. I 3D printed a cable pass through to fill the hole when running the cable through it to keep critters out. Otherwise the screw in plug is there.
07-19-2024, 03:21 PM
I just finished mounting the Dish connector for my Isata 3 Freedom Edition that I posted in my earlier post. I am pretty pleased how it turned out.
I just upgraded my Starlink Gen 2 hardware to the Gen 3 hardware and it is nice they have gone back to an RJ-45 connector w/ CAT6 cable.
There are a few companies now making ethernet adapter for the Gen 2 hardware so you can use regular CAT6 cable.
https://www.amazon.com/STARGEAR-Star...s%2C105&sr=8-6
Previous Coaches:
07-19-2024, 05:34 PM
An option to consider. I used a simple cable port to provide access for my Starlink cable. This is designed to be weather-proof and gentle on the cable. You could even add the port to a hatch door...or the wall around the hatch. I used a 4" hole saw to cut the opening, and then it took a bit of caulk and some screws to install it.
Jim Moore
SW Colorado - 4-Corners Area
2020 Jayco X213 Rear Slide, 2006 RAM 1500 with Firestone Airbags No WDH
400 watts of solar on the roof & 200 watts of suitcase & 2 x GC2 batteries
Starlink Gen-3 running from a 500 watt pure sinewave inverter
Boondock almost exclusively on the shores of Lake Vallecito
07-19-2024, 08:40 PM
I use a hatch in the inside wall of a bin. Leaving it open when in use. I suspect a closed small bin will get to or be over the temp max on a hot day.
For the mini, no worry as the router is in the antenna housing (which gets noticeably warm).
For me, the port is to get to my inverter when running off batts. With the mini I will likely use a portable battery and direct 12v to save the inverter power loss.
07-20-2024, 08:06 AM
It is the Gen 3 system. Can I use the existing cable connection that is built in for cable TV?
07-20-2024, 08:58 AM
No.... the TV Cable is coax and the Starlink Gen 3 is CAT6 with an RJ-45 connector.
I thought about removing the cable and satellite connection and replacing it with the RJ-45 I installed for plugging in the Dish..... but when I found relatively easy place to add it I decided to keep the Cable connection.
Previous Coaches:
07-20-2024, 09:58 AM
At least on the M2 chassis, the door seals are large and soft so you can run a cable through the doors, which I did. No problems.
2021 Dynamax DX3 37TS
07-20-2024, 10:13 AM
Insert witty title here
If you want to do this, I suggest buying a short extension cable that is long enough to reach from your router and through the door then plug your main cable into this. This way, all you have to do is replace the short cable if it wears out instead of the main. Maybe even carry a spare extension cable in case of a failure while traveling.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
08-02-2024, 08:41 AM
Norwood Auto Italia
And JIC it gets asked..I tried the coax to ethernet conversion boxes sold by Amazon and at least 2 did not work with Starlink. The idea was to use ethernet to interface with the satellite or cable coax links in the wet bay to connect to a cable distribution box in the media cabinet over coax. Just got snow.
2000 Sportsmobile E350 EB
2006 Renegade/Peterbilt K1854 and T1220
2021 Isata 5 28SS Explorer
08-02-2024, 01:28 PM
I ran my cable in through the slide out seal of my Salem 27DBK. If you have any slides, and you DON'T have a Swintek slide mechanism, extend the slide part way, push the cable out from the inside. Then lower the cable to the lowest point, observing while someone else extends the slide to the full extension. Worked well for me.
2018 Salem 27DBK/2010 Dodge Ram 1500 Laramie
Days past:1996 Coachman Capri-Ruby Ed. 27DS
2004 Ram Quad 1500
1995 GMC Yukon Sport
1986 Jayco1016PUP
Days Camped:'13-10 '14-20 '15-6 '16-9 '17-14 '18-3 '19-12 '20-14 '21-12
08-02-2024, 02:08 PM
Well said!
2018 Rockwood Ultra Light 2304DS, 2018 Ram 2500 4x4 Cummins
08-05-2024, 02:20 PM
Beware that starlink runs some Power over ethernet and so make sure if you're using a pigtail like that one shown it's capable of passing the amperage necessary to power the dish
2023 Europa 31ss
2015 Newmar BayStar Sport 2903
2003 Monaco Windsor 36DST
1998 Monaco Windsor 34PST
08-05-2024, 03:13 PM
The ones I ordered work just fine along with a good quality CAT 6 or CAT8 cable.
Previous Coaches:
08-07-2024, 02:20 PM
I was concerned about the heat in the compartment, so this is what I did.
I drilled a hole in the floor near the on demand water heater into the compartment. I used this:
https://www.amazon.com/dp/B0CWGZHBNJ...t_details&th=1
To route the following cable extension through the hole:
The hole went into the front compartment. The end hangs from the top of the compartment. I connect the cable that came with the antenna to this connector and it runs out a gap in the bottom middle of the compartment - there is no pressure on the cable.
The router and power supply are in an open top plastic box under the sink. the box has vents. I found a box of the perfect size at the container store. The box keeps the router and the power supply safe in transit.
The attachment has a picture of the plastic box under the sink.
I ordered this bag to hold the dish and the cable while traveling. I have not received it yet:
https://www.amazon.com/dp/B0BKTCCP5H...t_details&th=1
Things are working fine so far.
08-08-2024, 05:53 PM
Love that Gig bag for the dishy. I'm still using its packing box to hold everything.
I don't know what dishy you have. I have the Gen 3. It has a hoop-shaped kickstand, and I've been using a small sandbag through the hoop to keep the dishy planted where I put it...often on the roof of my rig.
Thanks for sharing the gig bag idea. I may get tired of messing with my box. For now, I've installed a 500 watt pure sine wave inverter on the wall in the top bunk area, and my power supply and router live on top of the box when setup...for air flow (THEY GET PRETTY WARM!!). I'd probably replace the box with something like a plastic cutting board to keep the electronics from sinking into the blankets and getting that much hotter.
Jim Moore
08-08-2024, 05:58 PM
I have a gen 3.
