Old 07-10-2020, 04:54 PM   #1
Lock's Avatar
Storage door latches
Has anyone had the plastic latches on the storage compartment doors break? I have a 2012 dynaquest 340. Iíve had two handles break, figured that out now I have two broken latches. The latches are held in place with rivets so might be complicated to replace. Anyway if someone has dealt with this please let me know how you resolved the issue.
Thanks in advance!
2012 Dynamax 340XL
2013 Toyota Tacoma
Lock is offline   Reply With Quote
Old 07-10-2020, 07:09 PM   #2
Motorized GM
Picture? We might be able to find someone that has worked on those before.
Please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx Don't forget to subscribe to our YouTube page for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
Old 07-11-2020, 09:30 AM   #3
Lock's Avatar
I’ll take some pictures and post.
2012 Dynamax 340XL
2013 Toyota Tacoma
Old 07-16-2020, 12:46 PM   #4
Lock's Avatar
Hereís some pictures
ID:	234021   Click image for larger version
ID:	234022   Click image for larger version
2012 Dynamax 340XL
2013 Toyota Tacoma
Old 07-16-2020, 12:50 PM   #5
Motorized GM
Ah, those are Wiley Manufacturing doors. We no longer use them and they are mad about that. They won't sell direct when we send people to them and want us to place minimum orders. So we can get them, but we have to order min qty's. Or dollar amount.
Old 07-16-2020, 12:57 PM   #6
Lock's Avatar
So any suggestions on what I can do? I would buy more than 2 as Iím sure more will break as time goes on. Also do you know the procedure for replacing? The back of the door is sealed.
2012 Dynamax 340XL
2013 Toyota Tacoma
Old 07-16-2020, 01:30 PM   #7
milkman55's Avatar
Post a picture of the outside of the door and also of one of the latches not broken. I doubt Wiley makes their own latches, probably an OEM part. I would drill out the two rivets on one of the latches, pull it and see if there is a mfg stamp on the mechanism. Donít be concerned with rivets, they are easier than screws in many ways. Home Depot or Loweís sell a cheap rivet gun set with many sizes of rivets.
2021 Isata 5 30FW
2014 Honda CR-V
milkman55 is offline   Reply With Quote
Old 07-16-2020, 01:39 PM   #8
Motorized GM
^^what Joel said^^.
I actually don't know, but I fired off the thread to Greg...he's been pretty busy but when he has a chance he'll chime in.
Old 07-16-2020, 01:51 PM   #9
milkman55's Avatar
OK, so I am camping in the Isata 5 in 100+ temps and it’s too hot to go outside. Let’s see if we can solve your issue.
The plates on the back at top and bottom are the pivot points for the latches that move when the center latch is pulled. If you drill those rivets, you should be able to access the horizontal bar that basically is the latch. Appears to have just broken off due to wear. Be careful when drilling the rivets to just go deep enough to dislodge the rivet and not touch the front face of the door.
I have never seen this style of latch with double strike plates and one handle, but you may find a mfg stamp if you remove the cover plates. Here is a cheap rivet gun to put them back after you remove.
https://www.homedepot.com/p/TEKTON-R...6555/207014968
Alternatively, if you still have the metal pieces that broke, you could get them spot welded at a local welding shop and reinstall. They probably have a pivot point behind the two upper and lower covers.
2021 Isata 5 30FW
2014 Honda CR-V
Old 07-16-2020, 01:54 PM   #10
Motorized GM
"we're gonna need a bigger boat". The diameter of that rivet looks huge. Maybe its the zoom level...
Old 07-16-2020, 02:00 PM   #11
milkman55's Avatar
Measure across the top of the rivet, probably a 3/16Ē. They sell stainless rivets at Home Depot that are 3/16Ē.
Another option is just find a welding shop and see if they can fix your latches. They will have the right size rivets. Some would have the capability of fabricating a new latch rod if you donít find who manufactured the entire assembly.
2021 Isata 5 30FW
2014 Honda CR-V
Old 07-16-2020, 02:48 PM   #12
Motorized GM
If you ever drive by the plant, you get two free nights at the campground. All owners get that. But if you want...you can walk out into the plant, go ahead and pick up some tools...as long as you do that, you can keep staying
win-win
Old 07-16-2020, 03:07 PM   #13
Lock's Avatar
Thanks for the feedback, Iíll drill out one of the broken latches and see what I got. The handle uses cables to pull the latches in to release. Thanks again, Iíll post when I figure something out.
2012 Dynamax 340XL
2013 Toyota Tacoma
Old 07-18-2020, 08:27 AM   #14
FOURWHL's Avatar
It wasn't identical but I was able to make this guy work. Had to adjust the length of the linkage
https://www.amazon.com/dp/B002PLW2DK...p_mob_ap_share
I just went back in with button headed self tappers with no issue. Though I do have a rivet gun on board nowadays
2016 Dynamax DX3 - Big Blue
https://fourwhl.com - Traveling the country in our DX3 for the next year
FOURWHL is offline   Reply With Quote
Old 07-18-2020, 09:01 AM   #15
Magnatudes's Avatar
In one of the photos it looks like TriMark handles so maybe ...
TriMark
Other TriMark Latches
Sold the Country Coach Intrigue & the '88 Honda Super Magnas
Got rid of the 2018 Isata 3 24RW
Got a Short M2 Triple Slideout Explorer
Where There's a Will, There's a Way
Fish or Cut Bait
Magnatudes is offline   Reply With Quote
Old 10-28-2020, 08:25 PM   #16
Lock's Avatar
I finally got around to replacing the latches. The ones referenced worked perfectly. The stainless steel reverts were a pain to remove but doable. Thanks for the help!
2012 Dynamax 340XL
2013 Toyota Tacoma
Old 10-28-2020, 09:34 PM   #17
Driving out the mandrel in the center of the rivet with a small punch, will make drilling far easier. From a guy who built an aluminum airplane, with 25,000 rivets.
rebel112r is offline   Reply With Quote
Old 10-29-2020, 05:43 AM   #18
Norwood Auto Italia
vlamgat's Avatar
Do you typically drive out the mandrel with a drill, or use a punch. My efforts to use a punch have usually ended in tears because the assembly is not robust enough to take the blows!
2000 Sportsmobile E350 EB
2006 Renegade/Peterbilt K1854 and T1220
2014 Born Free Triumph Royal (sold)
Isata 5 28SS on order
Various Airstream TT and Winnebago MH
vlamgat is offline   Reply With Quote
Old 10-29-2020, 01:13 PM   #19
Most of the 3/16 ss rivets, that needed to be removed, were on plate aluminum, so I never had a problem driving out with a punch, the same size as mandrel. Here is a copy of a method used in the industry, that I never used, different type of rivet I suspect.
door, storage
