05-27-2022, 03:51 PM
Storage options for batteries and solar
I am purchasing a 2020 ISATA 5 SERIES 28SS with Explorer Package. I live in sunny Florida and will have the unit stored in a covered location with no electric. How should I leave my battery settings and solar when it is being stored. Are there any links on this thread explaining the options.
05-27-2022, 08:38 PM
The best thing is to remove them and set them in your garage with a battery tender on them. Also check water level before storage.
05-31-2022, 11:03 AM
Thanks for replying
The RV shouldn't be sitting for that long. I am planning at least one trip a month I cant imagine taking out the four Lithium batteries every time I park it.
05-31-2022, 11:25 AM
Lithiums? Leave them alone, they're fine as is, save for charging or discharging in over/undertemp conditions. Since they're just sitting, you should be fine.
I'd make sure I had a solar disconnect for longer storage (to keep the panels from trying to charge in undertemp conditions), but that doesn't really apply to people not facing sub-freezing temps. (it's good practice to have a panel disconnect tho).
2022 Rockwood Roo 235S
2017 Audi Q7 3.0 Prestige w/air (yes, it actually tows that)
WeighSafe hitch - no WD or anti-sway
05-31-2022, 03:23 PM
50% SOC is what Relion and most other brands recommend
Now, how do you know what 50% SOC is maybe a better question? The chart from Relion does not clearly show what exact voltage at a specific temp you are looking for. The graph covers it but there is such a small difference between say 20 to 70 percent SOC. If your Victron BMV-712 has been working well, you might rely on that and try and leave your battery bank somewhere near 50% and disconnect them so there is no parasitic drain. The batteries won't discharge more than a couple % per month when disconnected.
For those leaving their rigs connected to the grid you can't do much unless you upgrade to the ME-ARC, the A stands for Advanced and it gives you more options. I upgraded to the ME-ARC and am testing some storage settings where the charger(Magnum) kicks in at 13 volts and uses 13.2 volts for the charging. This is far different from when they are in service and they are set to charge at 14.2 Volts. Seems we have a ways to go before the Lithium batteries are fully integrated?
2022 DynaQuest XL 3400KD CabOver, WD, Lithium Batteries, 4 190Watt Rigid Panels, extra inverter for AC operation w/o Genset.
05-31-2022, 03:36 PM
Commercial Member
One of the benefits of lithium batteries is they can charge at a much higher rate with no ill effects. What would the point be to lowering that to 13.2 volts unless you are limited on power?
We just did some testing here on a separate project....while plugged in, with the engine alternator going, we can charge 600AH's of batteries from depleted to fully charged in under 3 hours.
If "Search this Forum" does not yield an answer, please post questions as a "New Thread" (instead of sending a private message) so that others can benefit from the answers. Use Private Messages for sensitive information only.
Don't forget to subscribe to our YouTube page for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
05-31-2022, 03:53 PM
How to Store Lithium Batteries? Not how fast to charge them!
I am in total agreement that Lithium Batteries are a game changer in the RV world! Hence why I was devastated when my XL was delivered without the option I ordered and payed for. And I have done some testing while running one AC off the Lithium batteries via my extra Magnum Inverter so I am all in when it comes to seeing these batteries get charged quickly from either the Alternator, Grid or Solar or some combination!
But the OP is asking about storage, not the ability to charge.
I am trying to figure out a way to store my batteries at something near 50% SOC and so far, only one user on YouTube has really addressed this concern. I am positive the ME-ARC is part of the answer and I now have two of them in service. The CC/CV mode allows lots of options and yes, lots of complexity. If and when I find reliable data, I will share with the board. Oh, by running at 13-13.2 volts I am trying to keep the battery bank at something closer to 50% SOC.
06-05-2022, 06:27 PM
Brian,
I was more curious if it made sense to leave the solar on to give them whatever little charge I can get from being in a covered area. At the end of the day with the four lithium batteries I have is the best option is to just shut everything down and no need to charge them . I should be getting out or at least starting it once a month.
06-06-2022, 09:31 AM
Right from Relion;
If you are storing the battery and it is going to be below -20C then the battery is going to need to be moved indoors. RVs have parasitic loads that could completely drain the battery, so if you are going to store it in the RV above 0C then you should leave it connected with the solar on. If it is below 0C you should not charge them, so I would recommend disconnecting the batteries from the system in that case. So if above 0C use or store normally, below 0C use or store but charging must be limited, below -20C the battery should be moved to a warmer location.
I was concerned with winter storage in Canada.
2021 Isata 5 28SS Explorer
2017 Jeep Wrangler Unlimited Rubicon Recon
2017 Ram 3500 DRW
06-06-2022, 10:21 AM
I disconnect the solar panels in storage to keep the SOC reduced (normally 80% ish). As mentioned LiFePo life is reduced with long term 100% SOC storage.
2020 GMC Denali 4X4 2500HD Duramax
2018 Work & Play 25WAB
06-06-2022, 01:14 PM
Lithium batteries are best stored completely disconnected. I disconnect my single 300AH lithium using the disconnect which leaves solar and LI-BIM isolator (chassis batteries) connected. Mine is in a heated garage so it can sit month(s) like this although I rarely go more than a month given it is either used or I am doing something with it.
Almost all of them state to discharge to 50% but I'm confident you don't need to get to exactly 50%.
I have a 75AH ReLion lithium that I use for my Ocean Kayak with built in MinnKota motor (fishing). It sits for months disconnected and never loses charge. I've left it fully charged from time to time too.
2020 Dynamax Isata 5 36DS 4X4 (Super C)
2020 Ram 1500 Limited
Sold: 2015 Rockwood Ultralite 2604WS
No longer mine: 2006 Rockwood Roo 23SS
All pop-up and tent camping before...
06-07-2022, 10:02 AM
Brian,
I don't think a month or even two really qualifies as being in Storage based upon what I have read to date. I would simply try and not have them topped off when the end of your use comes up. Then, it would probably be easiest to hit the big disconnect switch and leave them disconnected because parasitic draw can be a pain, especially if you take an extra month to get back to the RV. I would also disconnect the solar but I don't see a switch on my system to disconnect the panels from the controllers. Hmmmm, perhaps another project....darn it.
