Strength Supports for Cargo Hold
There was recent discussion on the strength of the rotocast cargo floors. I decided to beef up one of the compartments. Not all of the compartments need to be stronger, but I did want to carry a propane tank and tools. My design needs space on the motorhome frame on the C channel. I chose the very last cargo box on the passenger side. The frame was clear and the box does not hang down as low. I bought two beam hangers that electricians use and a section of threaded rod. The beam hanger clamps onto the C channel frame. No drilling required. The threaded rod does into the bottom of the beam hanger and sandwiches the frame. I used angle steel but could have used the electricians channel that goes with the beam hangers. Towards the edge of the rig I needed a flat piece so I cut off a section and slid it over the outer most frame and under the rotocast. Let me put up a couple of pictures.
DYNAMAX 2016 FORCE HD
