10-19-2017, 03:33 PM
Surge protector
On my solera s , I had installed a sureguard protector hard wired in. Asked about getting one for my 2018 isata 3 and was told systems
Are smart and don’t need this item anymore
Just wondering if any other new owners installed one. Don’t want to waste money
10-19-2017, 04:01 PM
Location: Alberta - East of the Rockies, West of the Rest
I wonder if that statement comes with a written lifetime warranty. Sounds like a load of .........
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
10-19-2017, 04:04 PM
Just as confused as you
You were told BS. It doesn't matter how smart your system is, if it gets a higher voltage than normal your converter and other voltage sensitive appliances are going to suffer.
Your system is not going to notice a gradual rise in voltage, say from 120v to 150v and that is where damage will start to occur. What you need is a EMS (Energy Management System) that will monitor for gradual fluctuations in voltage.
Progressive Industries makes the best.
Richard & Jill
10-19-2017, 04:06 PM
That’s what I thought. Been at several campgrounds that the protector had tripped
10-19-2017, 05:20 PM
X2
I was told the surge protector installed at the factory is one and done. So I installed a Progressive Industries EMS.
Andy & Debbie Shultz
Harrisburg, PA
2021 Dynaquest XL 3801TS
10-19-2017, 09:00 PM
I went with this........
https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER
I can evaluate the power source before I ever plug in the coach, I can take it with me if I upgrade or remove it if it fails.
Scott & Heather
2018 Isata 5 DS
10-19-2017, 09:39 PM
I thought about that one too
But I understand they grow legs and walk away, especially since the new isata power cord isn’t permanently attached, so I went with a wired one
10-19-2017, 09:42 PM
That is one of the PI portable models, they also make a 30amp portable. I have a PI-HW30C hardwired that lets me see the condition of the power source. It will not let power pass through to the converter if it finds a problem. PI also has a HW-50C.
Richard & Jill
10-20-2017, 03:13 PM
I have an external as well, nice to see the power is ok at the pole.
2023 Dynaquest XL 3700BD
Had...2018 Force HD, 2016 Force, 2014 Thor 33sw
10-20-2017, 06:24 PM
Just plugging a portable one in with no load will tell you if the voltage is high but may not tell you if the voltage is going to be low until you put a load on it. Personally, I am going to put a hardwired one in.
10-20-2017, 06:35 PM
They do warn when the voltage is too low at the pole. I do not think the warning is tied to what load you put on it. Maybe I read something wrong. ;(
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
10-20-2017, 06:52 PM
Not necessarily true.
If the supply line voltage is above 132v, below 104v or line frequency above 69Hz, below 51Hz then the PI will show the error code immediately while shutting down the internal relay.
If you are connecting it before plugging in the RV, then the PI will not energize the relay while at the same time it will display the error code.
The PI portable models work the same as the hard-wired models. BTW, I have photos on the internals of a PI-HW50C.
I am not sure how the Surgegard models work because their not made the same as PI.
PI EMS 30 amp Error Code Chart PI
E-0 Normal Condition
E-1 Reverse Polarity Condition (hot and neutral wires reversed)
E-2 Open Ground (means no ground wire connection)
E-3 Line Voltage High (line voltage above 132)
E-4 Line Voltage Low (line voltage below 104)
E-7 Line Frequency High (line frequency above 69 cycles per second)
E-8 Line Frequency Low (line frequency below 51 cycles per second)
E10 Replace surge protector module
PI EMS 50 amp Error Code Chart
E-2 Open Ground
E-3 Line 1 Voltage High (Line voltage above 132)
E-4 Line 1 Voltage Low (Line voltage below 104 volts)
E-5 Line 2 Voltage High (Line voltage above 132)
E-6 Line 2 Voltage Low (Line voltage below 104 volts)
E-7 Line Frequency High (Line frequency above 69 cycles per second)
E-8 Line Frequency Low (Line frequency below 51 cycles per second)
E-9 Data Link Down
E-10 Replace Surge Protector Module
The instruction booklets are in the library section: Forest River Forums - Downloads - EMS-HW30C_HW50C_Installation&Operation
Error Code Chart: Forest River Forums - Downloads - Progressive Industries Error Code Chart
Richard & Jill
10-21-2017, 01:15 AM
Well...I only mentioned voltage levels, not frequency or neutral/ground swaps but yes, those others would be detected with a portable unit first by just plugging it in
10-22-2017, 08:40 AM
The key is what happens when there is a lightning strike to the power source?
10-23-2017, 08:54 AM
Commercial Member
I cry BS as well. I would always recommend a surge guard, on ANY coach. I am looking at different versions we might be able to make standard, but there are a lot of options.
10-23-2017, 01:49 PM
So Brian, is there a way to have a surge protector added to our order? We bought at the Pomona show and apparently they have not sent to orders to Indiana yet.
Kevin and Linda Knight
2018 Isata 5 30FW 4x4
dog-mobile for Sophie, Roxy, and Kai
Windsurf-mobile for us
10-23-2017, 02:48 PM
Looked under our new isata 3 w
And I see 3 grey bundles and 2 black bundles coming out of floor
I wonder if someone from dynamax could tell me if wires from landline plug in go through one of those
Thinking I could attach surguard to metal frame and wire there?
Unless you can suggest a better place.
10-23-2017, 03:32 PM
Commercial Member
We would not have time to add any surge guards to existing orders. That would require harness changes (at least for us) and design changes that we don't have slated in. Someone could likely do it aftermarket, or I would suggest portable.
Surge Guard 30A Portable with LCD Display | Technology Research, LLC
10-23-2017, 03:44 PM
30 amp? Even though the coach has 50 amp?
10-23-2017, 03:50 PM
Mine only 30
