05-25-2021, 12:40 PM
Switch under my stering in my Dynamax rev24rb
Could someone tell me what This switch do?
I try it and nothing apen!
Thanks.
05-25-2021, 01:24 PM
Commercial Member
Looks like it might be the emergency start switch. Pairs the house and chassis batteries in the event you drain the chassis batteries, so it will let you start the coach. OR, if you drain the house batteries, you can pair the other way so that you have enough power to start the generator.
05-25-2021, 01:59 PM
Thanks !
Its a good thing.
Appreciated your fast response.
05-25-2021, 07:15 PM
Confirming that if it is below and to the left of the steering wheel it is as Brian stated.
BTW, if you should ever need to use that switch you may what to hold it on for a minute before turning the key to put juice into your starting battery.
2017 Dynamax REV 24RB
2018 Ford F-150
05-25-2021, 07:41 PM
Thanks you, its good to know that it could help if necessary .
05-25-2021, 08:43 PM
One other thing which seems strange but worth keeping in mind.
I unplug everything that is connected to the USB ports and the 12 volt outlet in the dash.
I got into the habit of leaving my dash camera plugged in along with an occasional other gizmo. That ran down my chassis battery even though the camera and other things were supposedly off and the ignition key was in my pocket.
Wait, another one. If the battery gets run down far enough you won’t be able to turn the ignition switch. That is a major PIA gift from Fiat or Dodge. It is mentioned in the manual. Don’t try to force it. Some kind of safety or anti theft feature. I don’t remember. I only remember having really bad thoughts about the people who decided this feature was good.
I am getting started now; if the outside temperature sensor in your drivers outside rear view mirror is failing you will get wonky temperature readings on your dash display. Then you will notice that your dash air doesn’t work! It won’t work if the sensor fails. Then you have to buy a new mirror assembly. Another Fiat/Dodge good idea.
Finally, it is a pleasure to drive. Enjoy.
2018 Ford F-150
05-26-2021, 08:37 AM
Hi Bobby, engineers don't always think the right way, I'm an electronics technician and I think like a technician, I always care about how we can solve problems, that's why I have already modified some lack of the vr that I bought last summer! I have a 24rb and I mounted a wall with a recharged device behind the bench near the fridge! I removed the outside TV and I took two inverters. When I finish I post some pictures here to show you the results. All my boxes are made from a 3d printer! see you! thanks again for sharing.
05-26-2021, 08:42 AM
Yes, I would appreciate photos.
Outside TV?
2018 Ford F-150
05-26-2021, 09:03 AM
My inverters
Here I had a 32 inch TV and I installed my unverter and solar controller.
05-26-2021, 10:00 AM
Interesting.
Where is that compartment?
Can you post a photo of that side of your REV at your convenience?
2018 Ford F-150
05-26-2021, 10:29 AM
Kanadian Kamper
Originally Posted by Delco Bobby
Interesting.
Well, I don’t have 24 RB, but if he removed a television, it would be on the curb side of the vehicle. Then I’d look at the factory striping pattern to narrow down which compartment.
How many curb side compartments are there to choose from?
Do they all open downwards?
Ken and Terry
05-26-2021, 11:02 AM
On mine one small compartment holds the batteries and the other larger one with a side opening door. From memory my battery door opens up.
2018 Ford F-150
05-26-2021, 11:07 AM
My inverters
The compartment under the window above the box, in addition it is directly above the batteries so very short cable!
05-26-2021, 11:09 AM
Ok , i saw on your avatar that you don't have this one!
05-26-2021, 06:46 PM
I have a Dynamax REV24 RB.
You might have a different model REV.
2018 Ford F-150
05-26-2021, 06:52 PM
After taking a better look at your photo It seems you have a larger compartment under your dining window. My compartment in that area is much slimmer and contains my batteries.
What year do you have?
Where are your batteries?
2018 Ford F-150
05-27-2021, 07:05 AM
Its a 2015 and the batteries are under my big cover whit the inverter. Send you more photo and detail when finish the inside installation .
