Originally Posted by Rancher Rob
Lastly, I consulted a Victron/LiFePO4 expert and they said the Li-BIM225 are "crap" and there are much better ways to go. I'm going to explore a dc to dc converter.
Based on what I know about the Li-BIM's I agree.
They don't overcome the basic issue with different battery chemistries on the same charging circuit. They keep the alternator from "smoking" by merely charging the LiFePo4 batteries in intervals, controlled by voltage. If the alternator doesn't deliver 14.4-14.6 volts, then the LiFePo4 batteries aren't fully charged with balanced cells.
I'd go with a DC-DC charger and if it's absolutely necessary to maintain the Starting battery, install a second DC-DC charger in a smaller size that uses House battery to maintain the starting battery. They work both ways.
As for emergency start, a simple solenoid and push button solves that issue.
BTW, there are DC-DC Chargers available for less than the cost of a Li-BIM and two, one large and one small, may only be a few bucks more with far more reliability and performance.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
