Old 02-26-2020, 04:13 PM   #1
Jpheifer's Avatar
Tank gauges
These tanks are completely clean and empty - I can never get the gauge to go down to E always reads 1/3 - anybody else’s do the same ? Looking for a solution or a reason to stop trying to get this to change - thoughts please from Anyone with experience!
Joe Pheifer
DX3
Jpheifer is offline   Reply With Quote
Old 02-26-2020, 05:02 PM   #2
Originally Posted by Jpheifer View Post
Attachment 224035
Attachment 224036
Hate to say it but I think everyone here has had experience with this issue and it's pretty much normal for the standard OEM gauges.
All it takes to light these lights is for water/moisture in the tank to bridge the gap between the common (bottom) sensor and the next one up the line.
Your tanks may be clean and empty but I don't think they are DRY. Wait until the moisture drys on the walls of the tank and they'll show empty.
Most of us just ignore and kind of get a feel for when it's necessary to dump (or have water back up in shower; just look down through the open valve in the toilet with water turned off). Some invest in more expensive gauge systems that use sensors on the outside of the tank.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change)
Old 02-26-2020, 05:09 PM   #3
Commercial Member
This is still the BEST video to demonstrate this.
We started using these probes for a rental account when I was at Sunseeker. We were going to make them standard across the board but Mr. Horst could not meet the demand, so I think we sent this to Valterra and they bought the company, he retired.
If "Search this Forum" does not yield answers, please post questions as a "New Thread" (instead of asking privately) so others can benefit from the answers.
Subscribe for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
Sales-Service-Parts https://dynamaxcorp.com/contact-us
bclemens is online now   Reply With Quote
Old 02-26-2020, 05:33 PM   #4
SeaDog's Avatar
that is a great video.
Retired Navy
2016 Flagstaff 26 FKWS
Old 02-26-2020, 06:05 PM   #5
hhl
My tank 1/3 level probes are located at bottom on side of the tank.
Located left and right hand corner driver side of the tank. Isata 3
After a few trips my 1/3 level does not turn off. I use water wand and rinse inside the tank both inside corners for a few seconds.
This works for me.
hhl is offline   Reply With Quote
Old 02-26-2020, 06:36 PM   #6
Jpheifer's Avatar
Thank you that is about where I am at - not going to continue pissing up a rope - if it’s normal I am good with it - thanks everyone for the input
Joe Pheifer
DX3
Old 02-26-2020, 06:38 PM   #7
Doppleganger's Avatar
...the more you know! I'm thinking about replacing my probes before we even put anything in the tanks.
2016 Jeep Grand Cherokee Overland 5.7
2020 Coachman Apex Nano 187RB Outfitter & Off-Grid
Doppleganger is offline   Reply With Quote
Old 02-26-2020, 06:40 PM   #8
Jpheifer's Avatar
Thank you BC - most helpful - I’m good now and appreciate the great video-
Joe Pheifer
DX3
Old 02-26-2020, 09:22 PM   #9
I installed those probes in my rig and no more false readings.
DYNAMAX 2016 FORCE HD
houstonstroker is offline   Reply With Quote
Old 02-26-2020, 10:37 PM   #10
Jpheifer's Avatar
Are they hard to install - and where did you get them - they dynamax?
Joe Pheifer
DX3
Old 02-27-2020, 07:46 AM   #11
Jpheifer's Avatar
Orders the get water set from amazon - we’ll see how they go!
Perhaps should have looked before spellcheck hacked that to bits :
Ordered the grey water set from amazon - we’ll see how it goes!
Joe Pheifer
DX3
Old 02-27-2020, 08:06 AM   #12
halla's Avatar
I am adding external tank strips with bluetooth monitoring over the next month or so. We shall see if that helps or not.
2023 Dynaquest XL 3700BD
Had...2018 Force HD, 2016 Force, 2014 Thor 33sw
halla is offline   Reply With Quote
Old 02-27-2020, 08:52 AM   #13
Amazon, easy to install.
Old 02-28-2020, 01:21 AM   #14
Barch's Avatar
LINK ?
2019 ISATA 3 FW
LiFePO4 Upgrade
2013 Honda CRV Toad
Barch is offline   Reply With Quote
Old 02-28-2020, 05:54 AM   #15
Jpheifer's Avatar
Originally Posted by Barch View Post
LINK ?
Valterra T21302VP Horst Miracle Probe - Gray Water Tanks, Pack of 4 https://www.amazon.com/dp/B0136USMXW..._qfpwEbBW3NWYC
Joe Pheifer
DX3
Old 02-28-2020, 07:27 AM   #16
Canadian Member
The hardest part will be getting to the probes if you have the coroplast underbelly cover. I think Horst used to sell them in a set of 3 probes - black/grey/water.
Old 02-28-2020, 10:08 AM   #17
I also had a problem with false readings. Problem was solved by adding 1 cup of Dawn liquid soap to the black tank before a trip. Added about 5 gallons of water and let it slosh around while traveling. Next time tanks were flushed they all read empty! It was a cheap and easy solution to an aggravating problem.
2018 DX3 37TS Sunset
2019 Rubicon JLU
2022 RZR Pro 4 Ultimate
rskeans is offline   Reply With Quote
Old 02-28-2020, 12:40 PM   #18
Canadian Member
Here is a good video of installing the Horst Probes now sold under the Valterra brand name.
Old 02-28-2020, 01:39 PM   #19
Canadian Member
Jpheifer, the Horst/Valterra probes will be the simplest probe replacement solution. If you want more precise gauges, you can look at the SeeLevel II system. The SeeLevel system gives readings in percentages rather than just Empty, 1/3, 2/3 and Full, but its more work to install.
Ray from Love Your RV on YouTube has a series of 3 videos where he does an unboxing, installation and review of the SeeLevel system. Here's a link to the first video.
If you decide to buy either system, make sure you have a look at what your trailer has now so you know how many probes are on each tank and how deep in tank is.
Before you buy any of these probes, look into the "Geo Method" for treating your grey and black tanks. I also use RV Digest-It Holding Tank Treatment
Old 02-28-2020, 01:45 PM   #20
Commercial Member
I've used the sea level system prior to the Horst probes. For an individual, it is likely fine. Our issue was too much interference. They cannot be to close to each other, to metal and they're not potted (at least they weren't) so you can't really get them wet. I've heard good things...but for the money, we did not get the reliability that we wanted. Full disclosure, this was on rentals and over 5 years ago.
tank
