04-23-2018, 02:14 PM
Tank sensors
What adhesive is used for the black tank sensors. One of mine fell off. I stuck it back on but I know that won’t last.
Scott & Heather
2018 Isata 5 DS
04-23-2018, 05:08 PM
Same problem with my REV, I found the mid and top sensors dangling this weekend. Not sure which tank they go to. It looks like double sided foam adhesive strip. I'll be interested to see the correct answer.
Jerry Austin
2018 Dynamax Isata 4 25 FW
2011 Rubicon
2018 Dynamax REV 24 TB Sold 2/2021
04-24-2018, 09:03 AM
Our middle and upper grey tank sensors were dangling as well. Looks like they used duct tape originally, so that's what I went back with. I'm certain that won't be a permanent fix.
Interested to find out what others have had success with.
2018 DX3 37BH
04-24-2018, 09:29 AM
Commercial Member
It is a double sided tape. I think the issue is, no amount of prep seems to correct the release agent they put on the molds. Or maybe...it was just no amount of prep. Our guys are supposed to be wiping that area with a cleaner...I'll have to go audit that. My service guys uses a BASF adhesive promotor. You can get high just being near that stuff.
04-24-2018, 01:38 PM
Mine had several off when we picked it up. Caused a grey tank overflow issue.
Each sensor reads 1/3rd. Any 2, in any order, read 2/3rds. If your middle one falls off, the liquid will reach the top, the gauge reads 2/3rds, and then it floods.
I reapplied mine with a 3M double sided aircraft grade tape. SO far they have held.
I also moved the top sensor on the fresh water tank. it was physically located above the overflow, and would thus never read.
Scott
04-24-2018, 03:58 PM
Does it matter how thick the double sided tape is?
Scott & Heather
2018 Isata 5 DS
04-24-2018, 04:55 PM
I epoxied a depth sounder to the inside bottom of a sailboat, it shot through the fiberglass just fine & never came loose.
Dave & Julie - Motorhomeless for a while!
SOLD 2018 Isata-3 24FW - Invisibrake/Roadmaster Falcon All-Terrain Tow Bar/2019 Wrangler Sport S 2.0 Turbo
SOLD 2015 Tiffin Allegro 36LA/2014 Wrangler Sahara Unlimited
04-25-2018, 10:19 AM
I re-attached my sensors today. I find it interesting that both gray and black tanks have what appear to be built in sensors, yet the black tank also has two stick on sensors mid and full.
Jerry Austin
2011 Rubicon
04-25-2018, 11:35 AM
Commercial Member
1. The built in sensors are for the black and gray tank.
2. The stick on sensors are likely for the macerating toilet...separate sensors that come with the toilet.
If you don't have a macerating toilet...then someone might have changed them out?
04-25-2018, 11:43 AM
Thank you - very helpful!
Ron
04-25-2018, 12:58 PM
BC
No macerator toilet. I stuck them on the black tank because they were marked "Waste Tank, Med and High". I'll fill the tanks with water and see how they read. The two sensors did look like an after thought, they were from a 4 wire grey cable ty-wrapped to the flex conduit and only had two sensors, not three as I expected.
Jerry Austin
2011 Rubicon
04-30-2018, 09:58 AM
After reading this thread we took a look at our tanks, fresh, black and gray. The sensors all look permanently attached, no double sided tape anywhere so not sure what you all are looking at. Are we missing something?
Kevin and Linda Knight
2018 Isata 5 30FW 4x4
dog-mobile for Sophie, Roxy, and Kai
Windsurf-mobile for us
04-30-2018, 10:01 AM
Commercial Member
many of the units differ based on model.
