Old 10-14-2020, 10:13 AM   #1
Motorized GM
Testing our Solar Panels
We had a few suppliers come in and pitch their solar panels. I don't always trust reps who may have handicapped their competitors stuff, so we did our own.
Parameters:
We set up our 100w Go Power flex panel and a potential replacement.
We hooked them both up to their own AGM battery and their own Victron MPPT solar controller (so that we could track history).
Since the contender also claimed that their panel was wired in such a way so that it did not lose as much when shaded, we laid a 1x4 diagonally across each panel to see what that did.
Results are attached. Our current panel held its own, and while not a huge difference, it made the decision to stay with our current panel pretty easy.
Please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx Don't forget to subscribe to our YouTube page for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
bclemens is online now   Reply With Quote
Old 10-14-2020, 10:27 AM   #2
SeaDog's Avatar
This is the kind of stuff the solar techs live for nice comparison You have the go power what was the other panel?
Retired Navy
2016 Flagstaff 26 FKWS
Old 10-14-2020, 10:29 AM   #3
Motorized GM
That was a Merlin panel. I think a long term, one year test would be the most thorough....but this at least dispelled any early claims.
Old 10-14-2020, 11:22 AM   #4
FOURWHL's Avatar
The comparison panel was flexible as well?
2016 Dynamax DX3 - Big Blue
- Traveling the country in our DX3 for the next year
FOURWHL is online now   Reply With Quote
Old 10-14-2020, 12:25 PM   #5
KRedburn's Avatar
good question.
If a mounted panel not flex, I know of 380 watt single panels. that would be a game changer.
Ken and Kathy Redburn
2018 DX3 37TS (The Taj)
KRedburn is offline   Reply With Quote
Old 10-14-2020, 01:24 PM   #6
Motorized GM
yes
Old 10-14-2020, 03:56 PM   #7
Worm43's Avatar
On my 2017 Go Power Flexible panel. I get tops 7 amps out of one flex panel and the other is shot. I would say durability is an issue. I would go with two hard panels.
2017 Dynaquest 37XL RB "Thor"
2016 Jeep Wrangler JKU
Worm43 is offline   Reply With Quote
Old 10-14-2020, 04:09 PM   #8
Motorized GM
I have seen hard panels go out as well. I don't think a panel failure is indicative of the overall durability. There are lots of factors to weigh, including installation, weight, availability, etc. Almost all changes have unintended consequences (or affects, as consequences has a negative connotation"). In many cases you potentially trade one possible issue for another.
Having used different ones over the years, rigid panels have their pros and cons, just like flex panels. With the vast majority performing well, I am not in any hurry to change without long term testing and a history of hard data.
Old 10-14-2020, 04:40 PM   #9
Parameters:
I recently found a short u tube video on how to test your charge controller to ensure it's charging mh batteries. I'm technically challenged so I can't send you link however I think you can find it as follows
https://altestore.com/store/
it was put out in 2016 and runs 4:42
Thought I 'd share
Nomore9-5 is offline   Reply With Quote
Old 10-14-2020, 09:32 PM   #10
Go with lithium battery, you will get the most ah from your solar panels, lead acid and gel do not charge to 100%, your solar panel will only put out what is called for by the battery charge state, and what other devices you are using at the time
Daniel.mullins4 is offline   Reply With Quote
Old 10-15-2020, 05:46 AM   #11
The solar panel sales folks always want to point to the high noon direct sunlight output of their units.
Great for houses , but almost every RV parks in the shade when they can
The output in shaded conditions is far more important than high noon .
FFred is offline   Reply With Quote
Old 10-15-2020, 06:47 AM   #12
Whalenss's Avatar
Thanks for sharing test data. I like data driven decisions and that you continue to evaluate new products.
Pat
2017 Isata 5
Whalenss is offline   Reply With Quote
Old 10-15-2020, 10:58 AM   #13
Motorized GM
Attached is a short paper my EE sent that just talks about the Maximum Power Point. Adds some info to the MPPT controller.
Old 10-15-2020, 11:47 PM   #14
Just don't see this kind of inside look with any other manufacturer.
thanks!
V6TOY4X is offline   Reply With Quote
Old 10-16-2020, 08:23 AM   #15
Motorized GM
thanks!
Sometimes, I wonder if we give our competitors too much access to information. But I have always said...if you are copying, you will forever be behind.
Old 10-16-2020, 08:32 AM   #16
TrailWayz's Avatar
We saw a brand new Renegade Verona at our campground last week that was eerily similar to the Dynamax paint scheme. Until we got close I thought it was just a custom color order.
-Brian
2020 Isata 5 30FW 4x4
2019 Jeep Grand Cherokee Summit
TrailWayz is online now   Reply With Quote
Old 10-16-2020, 09:18 AM   #17
FOURWHL's Avatar
Not a direct comparison, but in my work in engineering we often worried about that as I was in niche fields. As it turns out it takes a lot more than a set of bootleg plans (or in this case forum post) to successfully execute a design. When you don't understand the underlying design decisions and philosophy, the details really aren't of much use.
Good on ya for keeping as open as you are! If you're constantly evolving they'll never catch ya.
Old 10-19-2020, 10:25 PM   #18
Curious. After your test, did you mount the two in parallel so you have 200 watts. Should not pose a problem.
Jim & Renee
2020 Jayco Jay Feather X-213
Every weekend boondocking in the National Forests or at Lake Wellington
jimmoore13 is offline   Reply With Quote
Old 10-22-2020, 02:57 PM   #19
Consumer of Space
I've been using rigid house panels on my RVs/Trailers for about a decade with good results. It's hard to beat the $/Watt and Watt/sq ft of a decent rigid panel.
We do a lot of Winter dry camping in the desert. The previous 1kW setup was just fine for most of the year, but couldn't keep up in the winter. I just finished updating my solar to the REC 330 NP panels. I was able to get five of them on the roof with fewer shading concerns than the older, larger Canadian Solar panels I was using. The REC 330 Watt panel is 66" x 40" compared to 77" by 39", which allowed two more to fit on the roof behind the air conditioner. The 60% increase should handle Winter just fine and I'll use the extra summer energy to charge the car.
I use the Morningstar Tristar 60 MPPT charge controller. These are built by electrical engineers like tanks, not copied from an existing design, and have really good efficiency. There are no moving parts and they don't mind an oversized array. I'm able to charge 60 amps into 24V batteries for 1,440 Watts max into the batteries.
I know the average Joe doesn't want/need a solar setup like mine, it's just hard for an engineer to resist...
2018 Dynamax Force HD 37BH
sconnors11 is offline   Reply With Quote
solar, solar panel
