Old 08-07-2022, 02:26 PM   #1
twp5253's Avatar
Thermostat not working on Fwd AC
22 XL
I knew I should have checked more than just to see the AC units produced both heat and cold. My forward AC, once turned on will not turn off. Rear AC unit is working perfectly and keeping at least one spot nice for my dog when I am out riding. Is this an easy fix? What is likely the problem?
2022 DynaQuest XL 3400KD CabOver, WD, Lithium Batteries, 4 190Watt Rigid Panels, extra inverter for AC operation w/o Genset.
twp5253 is offline   Reply With Quote
Old 08-07-2022, 06:57 PM   #2
Commercial Member
The A/C or the fan? Do you have the fan set to auto, low or high?
If "Search this Forum" does not yield an answer, please post questions as a "New Thread" (instead of sending a private message) so that others can benefit from the answers. Use Private Messages for sensitive information only.
Don't forget to subscribe to our YouTube page for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
Old 08-07-2022, 07:23 PM   #3
milkman55's Avatar
If your forward thermostat is attached to an outside wall or equipment chase that is on the outside wall, then heat from the wall keeps the thermostat thinking is hotter than it actually is in the RV. If you raise the set point on just the front thermostat until it cuts off, you may see a 4-5 degree differential between the front and the rear thermostat.
2021 Isata 5 30FW
2014 Honda CR-V
milkman55 is offline   Reply With Quote
Old 08-07-2022, 09:29 PM   #4
MoJoe1003's Avatar
Then replace your thermostats with these from Micro-Air, then you can program a temperature offset to reflect an accurate indoor temperature compared to what the thermostat is reading and the unit will shut off at the desired temperature. Plus, they are Bluetooth and WiFi enabled and you can change settings from your phone. If you have the Firefly system that’s part is not an advantage.
Joe & Cynthia
2021 Dynaquest XL 3801 TS Cindy 'B'
2021 Jeep Wrangler Unlimited Rubicon Diesel
“Breathe in, Breathe out, Move on”
MoJoe1003 is offline   Reply With Quote
Old 08-07-2022, 10:07 PM   #5
twp5253's Avatar
I asked to be on their Beta program last week!
Attachment 277593
I want one of these for the FWD AC unit so I can turn it on while driving using my iPhone. They don't have one ready for the GE AC Heat Pump units but it will be here soon.
Old 08-07-2022, 10:09 PM   #6
twp5253's Avatar
We have a winner...found problem in the mirror
Seems I had Fan/Auto in the back and Fan/On in the front. My bad. Thank you, you solved another one. I remember being in IT and often the problem was attached to the keyboard on a regular basis
Old 08-07-2022, 10:22 PM   #7
EdandShelley's Avatar
Attachment 277593
Waiting impatiently for these to replace the Atwoods. Thanks for letting us know about these, Joe.
EdandShelley is offline   Reply With Quote
Old 08-08-2022, 05:20 AM   #8
Steve & Linda M.
MevetS's Avatar
Back in the day we used to call it a I/O error. Could stand for Input/Output but also for I***t Operator.
Started back in '82 and cheap beer was good enough. "Pumpkin" '79 Burnt Orange Dodge "Street Van" Round trip to Alaska '87 ~ 10kMi - hope 2 repeat. Since 1994 Tioga Montara (new), 2006 Jayco Jay Flight 5th Wheel (new), 2015 Thor Siesta (new - Workmanship sucked) & 2017 Tiffin Breeze (Used -Workmanship decline cont.)
Another big RV learning experience.
2019 Jeep KL (Cherokee) TOAD
MevetS is offline   Reply With Quote
Old 08-09-2022, 10:09 AM   #9
So...
Attachment 277593
So it's 90 outside and when you set the room to 70 it doesn't cut off until the actual room temperature is 65. So you program a 5 degree offset, right?
And the next day a cold front comes through, and the thermostat is set at 70 but the room only cools to 75 and you are warm because the offset is still there, right?
offsetting the inside thermostat based on the varying outside ambient temperature makes no sense to me.
Larry
Larry-NC is online now   Reply With Quote
Old 08-09-2022, 10:19 AM   #10
KRedburn's Avatar
It is referred to as PEBKAC!
Problem Exits Between Keyboard and Chair
Ken and Kathy Redburn
2018 DX3 37TS (The Taj)
KRedburn is online now   Reply With Quote
Old 08-09-2022, 10:49 AM   #11
MoJoe1003's Avatar
It is not setting an offset based on the outside ambient temperature. The offset is set based on the actual interior temperature. Based on location, the thermostat may indicate the interior temperature is 75 degrees when it may actually be 78, so if set to 75 degrees it will shut off and the interior of the coach is really 78. By setting a 3 degree offset the thermostat shuts off at the room temperature when it is actually 75. The reverse of this can also happen, of course. To accomplish the offset you must use a stand alone thermometer, somewhere closer to the center of the room, to determine actual room temperature vs. what the thermostat indicates it thinks it is. The standard thermostats in most of our coaches do not allow for this adjustment. The Micro-Air thermostats do.
Joe & Cynthia
Old 08-09-2022, 11:07 AM   #12
Well, yes, but...b
Well, yes, but if the REASON for the offset is that the thermostat is mounted on an exterior wall that affects the sensed temperature, then the offset will be dependent on the outside air temperature.
You are suggesting that the deviation is constant. In this case it is not.
Larry
Old 08-09-2022, 11:13 AM   #13
MoJoe1003's Avatar
Not suggesting the deviation remains constant year-round or in all situations, angle of the coach relative to the sun can have a detrimental effect. All I know for sure is it works in my coach very well and if I need to change the offset a degree or two I can do it from my phone through the Bluetooth or WiFi capability of the Micro-Air thermostats.
Joe & Cynthia
Old 08-09-2022, 11:16 AM   #14
milkman55's Avatar
Another option is to add a spacer behind the thermostat and raise it about 1/4” from the wall. Insulate in the opening and reattach the thermostat.
Since this was done on my Isata 5, I no longer have issues with the front thermostat being different from the rear.
2021 Isata 5 30FW
2014 Honda CR-V
thermostat
