Old 03-04-2021, 01:08 PM   #1
Class C noobs
Thermostats in Isata 5
Quick question, or maybe just confirmation.
Does the front thermostat control the front AC unit AND the propane furnace, and the rear thermostat only control the rear AC unit?
Just checking as turning on only the rear t-stat to furnace heat results in nothing, but front works fine for heat.
Thanks!
AdventureAwaits is offline   Reply With Quote
Old 03-04-2021, 01:21 PM   #2
milkman55's Avatar
You have it right. Front is AC and furnace, rear is a AC.
2021 Isata 5 30FW
2014 Honda CR-V
milkman55 is offline   Reply With Quote
Old 03-04-2021, 01:54 PM   #3
Kanadian Kamper
kenandterry's Avatar
Too bad. That means you have to get out of bed IN THE COLD if you need the furnace before morning.
I’d rather have control of both from the bedroom.
Oh well.
Ken and Terry
2018 Sunseeker 2430S-CD
and if we ever need it, can be pushed by our 2017 GMC Terrain toad (4 wheels down)
Former Georgetown 330TS owner for 10 years with more mods than I can count.
kenandterry is offline   Reply With Quote
Old 03-04-2021, 02:05 PM   #4
Motorized GM
Oh well.
With the multiplex system we are running today, you can control it from the comfort of your covers via smartphone app.
Please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx Don't forget to subscribe to our YouTube page for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
Old 03-04-2021, 04:31 PM   #5
mjbenedict's Avatar
For us older unit owners (2020 - old ) one can purchase thermostats like these and do that via wifi or bluetooth. https://www.microair.net/products/ea...-rv-thermostat
I just added them to my unit, plugs right in. Also added some sealing behind the thermostats so they weren't so susceptible to drafts and high temps in the instrument column.
2020 Ram 1500 Limited
2020 Dynamax Isata 5 36DS 4X4
Sold: 2015 Rockwood Ultralite 2604WS
No longer mine: 2006 Rockwood Roo 23SS
All pop-up and tent camping before...
mjbenedict is offline   Reply With Quote
Old 03-05-2021, 07:34 AM   #6
Too bad those fancy ones won't work on my 2017.
I've got the atwood air command units in mine. I do have cute little IR remotes for them though. I've never checked to see if my rear thermostat can control my furnace though. Gonna try it today.
Phreak480 is offline   Reply With Quote
Old 03-05-2021, 09:20 AM   #7
Dynamax Isata 5 FW
van_fl's Avatar
On my 2019 I5 30fw both units control elect. Heat and furnace.
van_fl is offline   Reply With Quote
Old 03-05-2021, 09:43 AM   #8
I was told that in some units, you can set the Heat pump to work at a temp, lets say 70*, then when it drops below 40-45* outside it will shut down the heatpump and turn the Gas Furnace on automatically.
In my 2021 30FW I have been doing all that manually. Is the Gas Furnace wired in like that to do that switchover automatically???
2021 (Dec) Dynamax Isata 30 FW Xplorer
toshu is offline   Reply With Quote
Old 03-05-2021, 09:50 AM   #9
Motorized GM
In theory, yes. If you are set to heat pump or heat strip (electric heat) and it is 5 degrees below set point, it should automatically change over to furnace.
Old 03-05-2021, 09:52 AM   #10
milkman55's Avatar
My furnace kicks in automatically if the electric heat strips can’t maintain the set point. I do not know what temp kicks in the propane furnace.
Our issue is sometimes you need AC at bedtime, but heat before morning. I set the rear AC to cool and the front AC to heat and that has worked OK in transitional weather.
2021 Isata 5 30FW
2014 Honda CR-V
Old 03-05-2021, 09:54 AM   #11
I gave it a try in my 2017 I5 35DB and my rear thermostat does not seem to trigger my furnace, even if I press the furnace button and turn on that function.
Old 03-05-2021, 11:18 AM   #12
TrailWayz's Avatar
Same here on my 2020. Both T-stats control electric and furnace heat.
-Brian
2020 Isata 5 30FW 4x4
2019 Jeep Grand Cherokee Summit
TrailWayz is offline   Reply With Quote
thermostat
