Originally Posted by John Russ
What would be the average tire pressure for a 2010 Dynaquest 302.
John Russ
This is a much discussed topic of the forum. Search "tire air pressure" in the search box and you will see a whole lot of info about tire inflation pressure. At the least, you will need to know the weight on each axle and the manufacturer and size of your tires. Also, each major tire manufacturer posts a tire inflation pressure/weight matrix to give you their recommended cold tire inflation number. Search, understand the data and you will find your answers. Good luck.
