01-01-2017, 12:32 PM
Tire blow-out advice
I know, keep tires properly inflated by actual weight, inspect before every trip, and don't overload.
We had tyron bands on our class A and did have a blow-out (right front) while I was driving. Very frightening, I was afraid before, never drove it after.
Anyways, despite severe vibration, the coach did not careen from side to side, i was able to let it slow down as I eased it off the road. No damage to coach, tire did not come off rim, no damage to rim at all. I would say they worked as designed. However we had to wait on I95 for 5 hours and luckily the guy was able to "pry" the tire off the rim. He had a hell of a time and told us if he knew there were tyron bands he might not have come!!!
So what do you all think about Tyron bands or steering stabilizers. Wondering if we should look at something for our new coach. This forum is great for advice
Kevin & Jean
2018 DX3 37BH
01-01-2017, 02:23 PM
We added an ez steer, supposed to help greatly will blow outs. It also made it easier to drive on highway in my opinion.
2016 Dynamax Force. Just-Rite2
2023 Dynaquest XL 3700BD
Had...2018 Force HD, 2016 Force, 2014 Thor 33sw
01-01-2017, 02:31 PM
Ditto on that
I put on Safe t plus- Same concept
just do it
01-01-2017, 09:49 PM
I just realized i used the safe-t-plus too. Ez steer was for something in my side by side. Sorry about that
01-02-2017, 09:56 PM
So who installs these things? Will dealers do it or you have to find a garage?
Kevin & Jean
2018 DX3 37BH
01-03-2017, 07:57 AM
I installed it myself, but I know that our RV dealer installs them, General RV. I know Camping World does it too, but I would not have them do anything around here (Ohio), just my opinion.
01-03-2017, 09:59 AM
I got freightliner to do it but parts have to come from RV dealer
You ll need the bar and mounting kit
01-03-2017, 08:31 PM
Install was easy, the hardest part was adjusting, had to drive it about 15 miles and stop every so often to adjust with wrenches.
If you have someone install it, emphasize that you need it adjusted properly.
01-03-2017, 08:39 PM
Commercial Member
Well it looks like the tyron ring did what it is suppose to do. You also provided some insight on the downside of the unit.
While you are correct that knowing the weight and proper inflation number you have also learned that the ring will not prevent either air loss or belt separation. (learn the difference in this post)
Maybe something to consider is to take the steps necessary to prevent a failure in the first place as the ring only addresses the "after" a tire has failed.
.Write a blog on RV tire application RV Tire Safety. 48 years experience as tire design & forensic engineer. My RV Freelander 23QB on Chevy 4500 chassis. Giving seminars on RV Tire applications (not selling)@ FMCA Conventions. Mar 20-22 Tucson AZ
01-03-2017, 10:42 PM
Agreed, but thinking I'd like something in place should a blowout happen again despite proper tire care. With out the Tyron issue of many cant/don't want to deal with it
Kevin & Jean
2018 DX3 37BH
01-08-2017, 06:20 PM
Commercial Member
Sorry, there is no Free Lunch. Have you confirmed if the failure was from running low pressure or was it a belt/tread separation? Only way to know if you had proper inflation just before the failure is to report your hot pressure readings.
01-08-2017, 11:29 PM
Couldn't report anything we were on the side of I95 middle of nowhere going south. All I know is tired blew out on inside, there was a hole. Front passenger tire.
Kevin & Jean
2018 DX3 37BH
01-09-2017, 02:27 PM
Commercial Member
Well that's a perfect example of why it is important for everyone to have a written record of the tire DOT, size and brand info on file with other important information you keep for other components of the RV such as Refrigerator, Furnace, Generator, TV etc.
Many complain about the poor durability of tires in RV application but very few bother to take the basic steps needed to get the information to the DOT. NHTSA (department of DOT) can investigate products if there are sufficient complaints received and if they find an automotive component doesn't meet the required standards they can order a recall. Recalls can result if replacement tires being given of owners.
However for a complaint to be minimally helpful in establishing poor performance the full DOT (including date code) is needed. All too often there is confusion in the terminology of tire company, brand and model. Some owners do not provide the correct of complete tire size giving info such as 225-15 for example.
I have a number of posts on my blog about recalls and NHTSA if people want to learn more.
If not interested in getting better performing tires on your next RV that's your choice but I have little compassion for people who have problems but aren't willing to spend 10 minutes filing an actionable complaint. Remember a bit@# session around the campfire or on an RV forum will never result in an improvement in RV component quality.
01-09-2017, 04:33 PM
We always had all info on anything in, on the RV, including tire info with us at all times including that day. Since it happened years ago, we've told the story to many campers, and RV dealers (we just traded that coach and waiting on new one) You are the first person to ever suggest that there should have been a report filed. I will remember that and hope there's not a next time, but god forbid, if there is I know what to do. Thank you for that, but don't assume we don't care about the quality of our RV tires. We didn't know it should be reported.
Kevin & Jean
2018 DX3 37BH
