I had to converse that to liters and from kg to lbs , and found out that 100gallon full tank is 830 lbs.
But how far behind the rear axle?
I estimate it to give 1000lbs more on rear-axle, and 170lbs less on front-axle.
Can you also give me totall length , and wheelbase. I will use it for one if my onorthodox ideas.
In holland most motorhomes are between 5meter= 16 foot and 8meter= 27 foot.
This because of the driverslicence most europeans only have.
B driverslicence , may drive cars up to 3500kg= 7700lbs, and 8 passengers max.
Found out by 8 measurements, people gave, that standard motorhome ,total gravity point is between 41 and 45% of totall length behind front.
Now I want to see if this also goes for the larger American motorhomes.
Nice would also be distance front to front-axle. If not given I use 90cm/3foot for it.
