Old 08-03-2021, 12:20 PM   #1
Norwood Auto Italia
Tire pressure sensor needed?
I have determined that one of mine has failed but my dealer advises they are "unobtainable" so would like to search out an alternative source.
Does anyone have a P/N handy 2020 RAM 5500/Isata 5?
Update: RAM dealers will not disclose the part numbers they order under warranty (so my dealer tells me) so this request my be impossible to address.
Here is a clue JIC - 2 P/Ns are in the database for Rear - Inner - 5500: 68377549AE or 68455823AD but no hint as to which. I suspect the former is exclusive to the 3500 HD but....
2000 Sportsmobile E350 EB
2006 Renegade/Peterbilt K1854 and T1220
2021 Isata 5 28SS Explorer
vlamgat is offline   Reply With Quote
Old 08-03-2021, 01:58 PM   #2
We have 3 sensors which are Kaput and the last 4 dealers we called, while on the road, where laughing when we asked if they have them in stock. It will take a while, since apparently those sensors fall under the chip shortage category.
msusslin is offline   Reply With Quote
Old 08-03-2021, 02:20 PM   #3
Norwood Auto Italia
For sure - thanks. Do you know what P/N you are asking for?
Old 08-03-2021, 03:30 PM   #4
No idea what the P/N is, but all 4 dealers knew about the TPMS issues. Our dealer in CA kept telling us that resetting them is the fix, but after 3 visits we finally realized that they did not understand the issue. Hendricks in South Carolina told us the only fix is replacing all sensors. Those guys by far seemed to be the most competent service department we found along the way.
Old 08-04-2021, 07:46 AM   #5
Lvnthedream's Avatar
Yes, Iím in the same boat, I have two that act up. Been on order for months. I havenít asked for the PN but will. Iím tired of the error message popping up.
2021 Isata 5, 34DS
Colorado
Lvnthedream is offline   Reply With Quote
Old 08-04-2021, 08:50 AM   #6
Norwood Auto Italia
Mine started on my delivery ride. Followed by a segment 2 months later when 2 and then 3 went out. This was not replicated over subsequent segments. Function always returns when the tire cools down or the pressure drops below 103. But I was unwilling to wrestle with the dealer until I had to deal with extraordinary tire wear on the fronts and wanted an alignment. Turned out neither was possible because of the weight/height of the coach and as I have discovered, no parts.
Interesting enough, there are part numbers that address this function available from several dealers, namely: 2020 RAM 5500, Rear Inner sensors. I have identified 3 at least but am unwilling to order any or all 3 just because this is not a plug and play process requiring lengthy (get-in-line) visits to HD Truck Tire establishments with little time or patience for the amateurs.
Old 08-04-2021, 09:17 AM   #7
Have you checked large tire store chains?
NavyLCDR is offline   Reply With Quote
Old 08-04-2021, 01:07 PM   #8
Norwood Auto Italia
I have ordered from the Mopar wholesalers and I have ordered from 2 but both have advised after taking the order that delivery is indefinite. None of the retail tire guys handle these as they do not service OTR tires at all.
Have to go through HD Truck stores but they do not handle little trucks (RAM, Ford and Duramax) although they do sell and service 19.5" OTR tires.
Old 08-04-2021, 01:17 PM   #9
How about a aftermarket one
https://www.truckid.com/standard/tpm...&url=140585532
merchjo is offline   Reply With Quote
Old 08-04-2021, 01:24 PM   #10
Norwood Auto Italia
Originally Posted by merchjo View Post
These have a terrible reputation as not only Chinese rejects (the ones they cannot sell as branded products because they do not meet OEM tolerances) but also not compatible with the changing and various OEM receiver set up. The OEMs change the frequency, the coding and the data packet format from model to model and even tire to tire. Thus the P/Ns for front, rear, aluminum and steel wheels are different and vary from pre 2019 to post June 2021. Plus there also seems to be differences between the RAM 3500 HD and the 5500 C&C.
Lastly this is not just an issue of fitting them and seeing if you get a reading. The vehicle has to be driven at a constant speed for 20 minutes to communicate with the in cab receiver. So if you get it wring its back to the tire shop which for an inner wheel is a ton of work. Not in my budget.
Old 08-04-2021, 01:50 PM   #11
Try Rock Auto.
https://www.rockauto.com/en/catalog/...)+sensor,12036
Rick
Deerfield, WI
Rockwood Windjammer 3008W
and
Leisure Travel Vans U24MB
hunterrick is offline   Reply With Quote
Old 08-04-2021, 01:59 PM   #12
I was just trying to help
Old 08-04-2021, 03:26 PM   #13
Norwood Auto Italia
Originally Posted by hunterrick View Post
Thanks, they have the earlier models for the pre-2019 C&C and post 2019 2500 gasser SW RAM trucks. Unfortunately not the utility trucks.
Old 08-04-2021, 04:57 PM   #14
porsche84's Avatar
I bought a used Isata 4 early this year and it came with 6 spare sensors, TST IL-6 0618 (different than the sensors on the RV, but same brand TST). No idea if they work, but if they match the one you are looking for, I'd be happy to loan one or two and you return them when you get your new replacement
Jerry
Jerry Austin
2018 Dynamax Isata 4 25 FW
2011 Rubicon
2018 Dynamax REV 24 TB Sold 2/2021
porsche84 is offline   Reply With Quote
Old 08-04-2021, 05:31 PM   #15
Norwood Auto Italia
Jerry
Thanks however the Isata 5 needs sensors that specific to the RAM 5500 chassis, and often the year too. So none of us are free to do plug and play switching. I use TST sensors on my Toad and TPS Sensors on my trailer and neither are interchangeable although they look identical. And none of the these are interchangeable with the sensors supplied with my Toad Rv2 braking system even though they look the same as the other 2.
Its a forest out there!
Old 08-05-2021, 08:34 AM   #16
FOURWHL's Avatar
If you're already using TST why not just throw sensors on the Ram and use the TST fully?
2016 Dynamax DX3 - Big Blue
Full-time Dynamax Resident
FOURWHL is offline   Reply With Quote
Old 08-05-2021, 09:09 AM   #17
Motorized GM
I think Ram can disable the TPMS in the software if the light is an issue.
Please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx Don't forget to subscribe to our YouTube page for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
Old 08-05-2021, 09:36 AM   #18
See my post about TPMS here.... had all 6 replaced...they can be obtained.
https://www.forestriverforums.com/fo...rs-237562.html
2021 (Dec) Dynamax Isata 30 FW Xplorer
toshu is offline   Reply With Quote
Old 08-05-2021, 10:26 AM   #19
TrailWayz's Avatar
I asked my Ram dealer about disabling the factory TPMS last year and was told they are unable to since its considered a safety feature. I've learned to just ignore the warnings when they occur and tap the steering wheel arrow to restore my preferred dash view. It's not terribly inconvenient.
With the TST system the factory set-up is redundant and unnecessary since the TST also covers my TOAD.
-Brian
2020 Isata 5 30FW 4x4
2019 Jeep Grand Cherokee Summit
TrailWayz is online now   Reply With Quote
Old 08-05-2021, 11:35 AM   #20
Folks have been able to to it on the 4th gen rams using certain non dealer scan tools. Dealer won't even adjust pressures anymore (the ability got removed from their witech software)
Phreak480 is offline   Reply With Quote
tire, pressure
