Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 06-22-2019, 06:32 AM   #1
Transfer Switch
I have a 2017 Force. Has anyone had the transfer switch fail ? MH is plugged in
at home to a 30 amp. service. Went outside and could hear a chatter noise, sounded like a thump-thump. Traced it back to the transfer switch. Unplugged it at the house and noise stopped, plugged it back in and it started again. I called the manufacturer (SOUTHWIRE) and explained what was happening and they said either low voltage or the unit is no good. I checked voltage and all was good. I pulled the cover and made sure all connections were tight. We were leaving for a 4 day trip but wouldn't need a 120v because we would be boondocking and I could use the generator. I ordered a new switch and I would have it when we got back. Came home and plugged it in to see if it was the same way. To my surprise it was working. I had received the new one so I decided to keep it, which was good because two days later it started the thumping noise again. The noise is the switch going on and off, unable to stay in the on position, not making contact. Has anyone had this problem and did you change it yourself or did you bring it to a shop. Any ideas or suggestions would be helpful. Thanks
RITAOB is offline   Reply With Quote
Old 06-22-2019, 07:32 AM   #2
Webefine's Avatar
Never had a problem on my DX3 but a friend bought a new 5th wheel and the day he brought it home and plugged it in the transfer switch failed. It kept making chattering noise and wouldn’t connect on the shore power but worked on the generator power. The factory sent him a new one and I changed it for him, pretty simple and straight forward.
Webefine is online now   Reply With Quote
Old 06-22-2019, 08:20 AM   #3
Sunset beast's Avatar
Yes, I had mine failed 2016 DX3 while on a trip in New York, had to install a by-pass on the shore power switch until I got home to make a appointment the generator switch worked fine and funny thing Southwire says they’re not rebuidable/repairable.
David & Tracy
2016 DX37TS
Greensburg, Pa
Sunset beast is offline   Reply With Quote
Old 06-22-2019, 11:18 PM   #4
DavidMort's Avatar
Ours failed on an I5
See this discussion: http://www.forestriverforums.com/for...in-183663.html
2017 Isata 5 DS
DavidMort is offline   Reply With Quote
switch, transfer switch
