Old 10-06-2020, 05:52 PM   #1
Trouble with stabilizer jacks on dx3 37rb
Have 2015dx3 37rb stabilizer jacks not working will not go up or down all lights on panel seem to work ok but jacks will not move either auto or manual. Checked fuses and breakers in panel checked fluid level (ok)pressed all buttons above reservoir still doesn't work. Anybody no of circuit breaker or fuse that I may have missed or something else that would cause this problem?
Joe-Barb is offline   Reply With Quote
Old 10-06-2020, 06:42 PM   #2
Retired Army Paratrooper
MasterBlaster's Avatar
There is an inline fuse at the pump motor. You have to dig around towards the the top of the motor. I believe it is a 5 amp.
Dennis & Zoleta
Retired US Army
2010 Grand Sport GT
MasterBlaster is offline   Reply With Quote
Old 10-06-2020, 07:30 PM   #3
Thanks for the tip. I checked the fuse and it checks ok. I changed it just to be sure still no response from the jacks. Panel goes thru it's cycle ok but jacks will not move. We have been traveling for several weeks and they worked fine. Came to our next stop and they just stopped working.
Old 10-06-2020, 08:02 PM   #4
I have a 2017 DX three and this happened to me one time. Unfortunately it was the computer board on the dashboard that was bad. But while I was reading the instructions it said that you can remove the board turn it around and unplug it and then plug it back in and that could possibly reset the system for you. But like I said mine was just a bad board and had to be replaced so that didn’t work. If you have the instructions for it it will also tell another way to reset it.
But I am not near my RV to get instructions.
Coopers8
Coopers8 is offline   Reply With Quote
Old 10-06-2020, 10:28 PM   #5
Thank you I will check that out in the morning.
jacks, stabilizer, dx3
