06-20-2021, 01:27 PM
Under slide wear
Should I be worried about this, if so how do I repair it, one is the kitchen slide the other is the bedroom slide
2018 Force HD TS37
2020 Jeep Wrangler Sahara
06-20-2021, 01:46 PM
Commercial Member
at the plant, we have sometimes put aluminum in that area. No thicker than the angle iron next to it...I think they glue and put some rivets in for good measure.
06-20-2021, 02:08 PM
I do not own a Dynamax, but I do own a TT with a slide. If my slide had marks on it like that I'd be very worried. Something is definitely amiss with that slide.
2016 Salem 27RKSS
06-21-2021, 10:32 AM
Thank you Brian for the response, there's an adjustment screw (see pic) in your professional opinion would an adjustment help take some pressure off that area?
2018 Force HD TS37
06-21-2021, 10:40 AM
Commercial Member
The slides do have adjustments points...but that can be a slippery slope.
06-21-2021, 10:56 AM
I thought it might be, thanks for the response
2018 Force HD TS37
06-21-2021, 11:08 AM
Commercial Member
If you mark where they all are today, with grease pencil or something, it will minimize the risk if you get too far off.
All depends on your level of DIY and risk appetite.
06-21-2021, 11:19 AM
Thanks again, I won’t be moving it far, but that’s good advice, I do a lot of business with area rv dealers with body shops, I will ask for there advice also, they should have a lot of hands on experience
2018 Force HD TS37
06-24-2021, 11:30 AM
Brian I need this mounting bracket. It's bent and ready to break, where can I get this?
2018 Force HD TS37
06-24-2021, 12:02 PM
Commercial Member
On the bottom it looks like a part number maybe? That whole assembly comes from LCI (Lippert Components). We get it in a full system, not parts.
06-24-2021, 12:05 PM
I'm not Brian, but that's called a 'Head Assembly'. Just so you'll have the proper name for it.
Gotta go campin!
06-24-2021, 12:20 PM
Commercial Member
Brian I need this mounting bracket. It's bent and ready to break, where can I get this? Attachment 257734
as a side note...I would direct questions to the general public, as many of them can come back with an answer faster and in a few cases more accurate than me. (OK, in many cases more accurate and in a very small handful of cases 100% wrong)
06-24-2021, 12:48 PM
If your handy and have a welder and a torch you could pull it off, straighten it and reinforce it so it doesn’t happen again. Unless of course the part is readily available.
2008 Dynaquest 340xl
Bill and Carol
Retired mechanic
US Army Veteran 🇺🇸
Previous coach 2017 Isata 3RW
Also,3 Diesel pushers, 1Bvan, 2 class Cs
06-24-2021, 06:54 PM
Thank you for all the information from everyone it was helpful
2018 Force HD TS37
06-26-2021, 03:11 PM
Agree, just make one or straighten and reinforce. Bring it to a welding shop and they can do this for you. Shouldn’t cost much.
—john
