Undocumented and Unaware - AUX 1 and AUX 2 Switches (2022 isata 5 28SS)
Discovered yesterday that the AUX 1 and AUX 2 switches were already allocated! This was news to me seeing there were two wires coming out from the connector block under the hood!
The curious part is what the heck are AUX 1 and AUX 2 being used for?
The functions for AUX 1 and AUX 2 were never disclosed by the dealer during the walk-around when taking delivery, nor has any Dynamax documentation been seen. AUX 1 was seen be set as a Battery feed (default) along with ON or OFF - it was also seen with about a 12 ga. red wire spliced-in too. AUX 2 was seen to be set as a Battery feed also and configured for momentary ON - it was seen with what looked like a spliced -in 16 ga. green wire. Nothing was heard or seen when turning AUX 1 on and off a few times. I did hear some faint solenoid "thumps" around the rig's middle right side when AUX 2 was pressed a few times. Both of the connector blocks' wires were spliced, ran back through the firewall (in front of the brake pedal), then going under the cab carpet. The wiring appears to have been done during the manufacture phase.
I was planning on using AUX 1 for powering an amateur radio VHF/UHF mobile radio, an Icom ID-5100A. Instead of using AUX 1 for powering the radio, the next one available was used, AUX 3, configuring it for a Battery feed (since it will be used occasionally when parked) and for ON or OFF.
The radio and antenna were finally installed and seem to be working great. It is nice to have 2m /70cm mobile in the rig now and should be great when back out on the road soon.
So, any ideas what AUX 1 and AUX 2 are being used for?
