07-25-2019, 05:18 PM
Utility side porch light
Was parked next to a tiffin at the last stop with a porch light right above the wet bay. Lindsay asked what is that for? I said actually... thatd make setting up in the dark a lot simpler
Now I guess something so simple will take years of harness design to charge, but anything that's been talked about before? Doable?
Seems pretty logical and useful to me
2016 Dynamax DX3 - Big Blue
07-25-2019, 05:55 PM
Our Seneca had one too. I agree it would be a good addition. On the Seneca it was called a "Security" light. I left it on all night along with the porch light.
Andy & Debbie Shultz
Harrisburg, PA
2021 Dynaquest XL 3801TS
07-25-2019, 07:02 PM
This is also offered on the Renegades. They have 5 total - 2 driver side, 2 passenger side, and 1 rear...all independently switched. I think it’s a great option as well.
2018 DX3 37BH
07-25-2019, 07:47 PM
Commercial Member
Lindsay, is even more my favorite now.
07-25-2019, 07:48 PM
Commercial Member
I had them on all my Forester’s. It has really never come up before now since we had the wet bay light.
07-26-2019, 12:39 AM
We had one on our 2013 solera
Don’t think I ever used it.
07-26-2019, 06:50 AM
On our Isata 5, I removed the original wet bay light because it was VERY dim and semi-obscured by the grey tank drain pipe. I replaced it with 10 small-ish LED puck lights around the bay door opening and they face _into_ the bay so the entire bay glows bright white when you have the cargo lights on. Makes setting up at night MUCH nicer and the light is bright enough that is casts outside onto the ground when in use and the door is open. One of the better ~$10 mods I've done, now that I think of it.
2019 Dynamax Isata 5 35DB
Audi "Nardo Grey"
07-26-2019, 07:16 AM
Hi,
I added small motion activated, solar powered lights in a couple locations where I wanted additional illumination.
Something like this...
https://www.ebay.com/itm/2Pack-Solar...242?nav=SEARCH
FWIW.
Rich Phillips
Rich Phillips
2019 K-2500 Duramax Crew Cab
2014 Silverback 33RL
07-26-2019, 10:57 AM
I added a section of LED rope light underneath the wet bay area and wired it into the wet bay light switch near the anderson valve.
I also saw a post a while back where someone used a magnetic/swivel based light stuck to the inside surface of the wet bay door. By opening the door different amounts, they could direct the light where needed.
2017 Isata 3 24FW
2004 Jeep Wrangler
07-26-2019, 12:24 PM
I'm old, I go to bed when it's dark and don't need the lights...
But I like the puck idea, I'm going to try that one. I have an LED strait light fixture I bought years ago, has a motion on/off switch that would be great in that application.
It looks like this: https://www.amazon.com/Motion-Sensor...37060456&psc=1
Old Navy Chief
2019 Isata 5 36' DS 4x4
2015 Jeep Rubicon Toad
Days camped 2021 = 25
07-26-2019, 02:45 PM
If you don't relish the idea of running wires, consider some battery operated puck lights. I have one in the electric bay and inside across from the pantry which is a bit dark. Installed with extra Command tape.
"Lurch" = Georgetown 2011 330TS
Toad = Jeep 2016 Cherokee
Pilot = Bob
First Mate = Xiangbing
Crew = Radar, NiuNiu & NaNa
07-26-2019, 05:05 PM
I just ran 30' of 2 AWG for my solar through the cab so I'm not against running wires. But this was more of just a design suggestion. I know there are plenty of work arounds and honestly my head lamp works fine also, just passing a tidbit along that might help dynamax compare with others
07-26-2019, 06:06 PM
X2....😎
2019 Dx3 TS
2020 RAM 1500 Limited Diesel 4x4
7 lb Guard Dog
Working hard on “elderhood”
07-27-2019, 08:14 AM
Its not wired, but a pretty easy solution if you need light.
https://gostikproducts.com/go-lite2/
2023 Dynaquest XL 3700BD
Had...2018 Force HD, 2016 Force, 2014 Thor 33sw
08-05-2019, 11:04 AM
These are the lights that we have in our wet bay now......actually, the wet bay was just my test run and I've done this in every bay at this point. With these on and the wet bay door open, they cast pretty good light outside the bay. I just "stole" the wires that ran to the original wet bay light (which had the light output of a Bic lighter) and connected them to my new lights. They are held on with double-sided tape. So, the install was virtually no tools and they've stayed put for almost a year now in everything from freezing temps in Colorado to 104 degrees in West Texas.
Audi "Nardo Grey"
08-05-2019, 11:07 AM
Audi "Nardo Grey"
08-05-2019, 05:05 PM
Originally Posted by BLT4SPD
Nice, that compartment could use more light, thanks.
