Old 11-28-2020, 12:48 PM   #1
Valve stem stabilizer
Has anybody found valve stem stabilizers for a 2017 Isata 3? The wheels are HiSpec and have oval openings. I want to add a TPMS but I think I will definitely need to support the inner tire valve stems.
Mmspring is offline   Reply With Quote
Old 11-28-2020, 01:07 PM   #2
Norwood Auto Italia
vlamgat's Avatar
I believe they are available individually on the Alcoa web site. Round and oval.
2000 Sportsmobile E350 EB
2006 Renegade/Peterbilt K1854 and T1220
2014 Born Free Triumph Royal (sold)
Isata 5 28SS on order
Various Airstream TT and Winnebago MH
vlamgat is offline   Reply With Quote
Old 11-28-2020, 02:14 PM   #3
milkman55's Avatar
The Hispec are not the same as Alcoa. I never could find a stabilizer to fit. I ended up using black silicone to anchor the stem to the inside of one of the openings. Downside is if you ever have the tire off, you would have to reseal.
3 years and 15k miles was never a problem.
2021 Isata 5 30FW
2014 Honda CR-V
milkman55 is offline   Reply With Quote
Old 11-28-2020, 02:16 PM   #4
Usually Confused Member
emm-dee's Avatar
ShinyRV has them.
https://www.shinyrv.com/product-cate...edes-sprinter/
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Old 11-28-2020, 05:46 PM   #5
Thanks for the replies. I looked at ShinyRV but they all appear to be too thin. The HiSpec rim has a very wide lip on one side.
Did you use Black silicone caulk or a black silicone adhesive?
Old 11-28-2020, 05:53 PM   #6
milkman55's Avatar
The Black Silicone Adhesive. It still will easily come off the metal when you remove a tire.
2021 Isata 5 30FW
2014 Honda CR-V
Old 11-28-2020, 06:03 PM   #7
emm-dee's Avatar
How many different types of wheels are put on the Sprinter? Shiny RV shows seven. When I ordered mine I wasn’t sure which one would fit so I called them to discuss the issue. Very good customer service.
Old 11-28-2020, 06:09 PM   #8
Thanks, I will try the silicone. I did see a new Isata3 at the dealership last year that had a TPMS with no stabilizer on a flexible valve stem but I would be concerned about the wear on the valve. Apparently Dynamax is putting them on the new units unless the dealer installed the TPMS.
Old 11-28-2020, 06:10 PM   #9
I will try calling Shiny RV. If they have one that fits I will let you know. Thanks
Old 11-30-2020, 08:31 AM   #10
Another source
https://yourtireshopsupply.com/
jentwistle is offline   Reply With Quote
stabilizer, valve
