Old 12-03-2020, 10:36 PM   #1
Victron settings from Factory??
Does anyone have the correct Victron setting for a 2021 Recent release Xplorer system? We are picking up our unit next week, and I want to connect the app and make sure that everything is set according to the proper factory settings for the Relion batteries supplied. Never know what a dealer might do.....
toshu is offline   Reply With Quote
Old 12-04-2020, 09:29 AM   #2
Ursusb's Avatar
The following setup was given to me by a Battleborn engineer but should be applicable to your new systems!!
BMV-712 setup:
Battery Capacity: Total AH of your bank of batteries*
Charged voltage: 14.4v but note that this # should be about .1 or .2 volts back of what the charging voltage is set to in your charging device*
Discharge Floor: 0%
Tail Current: 2-4% is good
Charged Detection Time: 3m
Peukert Exponent: 1.05
Charge Efficiency Factor: 99%
Current threshold: 0.10A
Time to go averaging period 3m
Battery Starts Synchronized: blue button should be to the right
State of Charge: leave alone
Synchronize SOC to 100%: Leave alone, this device will sync itself at the top of the charge
Zero Current Calibration: Leave alone
Ursusb is offline   Reply With Quote
Old 12-04-2020, 10:12 AM   #3
BMV-712 setup:
Discharge Floor: 0%
Sounds like you added BB Li batteries to your rig??
Old 12-04-2020, 10:59 AM   #4
Ursusb's Avatar
My rig (30 FW) did not have the lipo option at the time so my project for this fall/winter was to add lipo and extra solar.
Ended up with 3 BB 100ah lipo batts and added 2 renogy 175w solar panels for 550w total (the rule of thumb for solar and lipo is 200w per 100ah batt) in a series/parallel 24vdc arrangement for the panels.
I also removed the PWM solar controller and installed a Victron MPPT so I could run the 24v S/P solar in and 12vdc out to the batts. Rerouted the batt cables for the Victron shunt. Put the Victron headend into the spot on the pillar I removed the PWM solar controller. And the BIM 225 for the LiBIM 225 for chassis charging.
And on the 7th day rested.. working on this stuff, roof, batt compartment and under the rig does take a toll on these retired bones.
Címon spring!,!,!
Old 12-04-2020, 05:50 PM   #5
BMV-712 setup:
Discharge Floor: 0%
I used this post, which looks very similar (for obvious reasons) https://battlebornbatteries.com/conf...etooth-dongle/
WeQuit is offline   Reply With Quote
factory
