Wet bay hole fitting thingy????
Ok, I don't like the idea of my fresh water hose and sewer hose routing through the same hole, plus the water hose makes it difficult to hook to the sewer hose when they're in the same hole. You can't shut the bay door if the hose doesn't go thru the drain hole.
I want to add a second hose hole in thebottom of the bin but cannot find a fitting with a screw in cap like is installed under the sewer drain.
Anyoneknow what the proper name of these is?
2019 Isata 5 36DS
2015 Jeep Wrangler JKU toad
