Originally Posted by petrx
Yes Brian, I got the valves closed but the box right now is being held up with bungee cords as to not drag on the ground. Can screws be put through the top part of that box, mine only had screws (2) on the bottom, nothing holding the top.
OK, so what we have is an aluminum framed opening. On the outside, we have a plastic access door. On the inside is that wood frame. So you can screw ALL four sides. The trick is to make sure the screw goes through the frame and into the aluminum frame. But the aluminum frame should be four sided.
Here is what it should look like.
