Reply_By_Link_Only <Reply_By_Link_Only@chrysler.com> Fri, Mar 6, 2015 at 8:06 AM
To:
disoswam@bellsouth.net
Dear Mark:
Thank you for contacting the Ram Customer Assistance Center.
The GAWR is the maximum capacity of the front and rear axles. Distribute
the load over the front and rear axles evenly. Make sure that you do not
exceed either front or rear GAWR.
As required by National Highway Traffic Safety Administration
regulations, your vehicle has a certification label affixed to the
driver?s side door or BPillar.
If seats are removed for carrying cargo, do not exceed the specified
GVWR and GAWR.
Vehicle Certification Label
Your vehicle has a Vehicle Certification Label affixed to the drivers
side BPillar
or the rear of the driver?s door.
The label contains the following information:
? Name of manufacturer
? Month and year of manufacture
? Gross Vehicle Weight Rating (GVWR)
? Gross Axle Weight Rating (GAWR) front
? Gross Axle Weight Rating (GAWR) rear
? Vehicle Identification Number (VIN)
? Type of Vehicle
? Month Day and Hour of Manufacture (MDH)
The bar code allows a computer scanner to read the VIN.
The vehicle maximum load on the tire must not exceed the load carrying
capacity of the tire on your vehicle. You will not exceed the tire?s
load carrying capacity if you adhere to the loading conditions, tire
size, and cold tire inflation pressures specified on the Tire and
Loading Information placard and in the ?Vehicle Loading? section of the
owner's manual.
NOTE: Under a maximum loaded vehicle condition, gross axle weight
ratings (GAWRs) for the front and rear axles must not be exceeded.
To determine the maximum loading conditions of your vehicle, locate the
statement ?The combined weight of occupants and cargo should never
exceed XXX lbs or XXX kg? on the Tire and Loading Information placard.
The combined weight of occupants, cargo/luggage and trailer tongue
weight (if applicable) should never exceed the weight referenced here.
Steps For Determining Correct Load Limit
1. Locate the statement ?The combined weight of occupants and cargo
3/6/2015 Gmail Re:
Chrysler Group LLC Customer Assistance (KMM9026133V56165L0KM)
https://mail.google.com/mail/ca/u/1/...bef316db0cc95f 2/3
should never exceed XXX lbs or XXX kg? on your vehicle?s placard.
2. Determine the combined weight of the driver and passengers that will
be riding in your vehicle.
3. Subtract the combined weight of the driver and passengers from XXX
lbs or XXX kg.
4. The resulting figure equals the available amount of cargo and luggage
load capacity. For example, if ?XXX? amount equals 1,400 lbs (635 kg)
and there will
be five 150 lb (68 kg) passengers in your vehicle, the amount of
available cargo and luggage load capacity is 650 lbs (295 kg) (since 5 x
150 lbs (68 kg) = 750 lbs
(340 kg), and 1400 lbs (635 kg) ? 750 lbs (340 kg) = 650 lbs [295 kg]).
5. Determine the combined weight of luggage and cargo being loaded on
the vehicle. That weight may not safely exceed the available cargo and
luggage load
capacity calculated in step 4.
NOTE:
? If your vehicle will be towing a trailer, load from your trailer will
be transferred to your vehicle. The following table shows examples on
how to calculate total
load, cargo/luggage, and towing capacities of your vehicle with varying
seating configurations and number and size of occupants. This table is
for illustration
purposes only and may not be accurate for the seatingand load carry
capacity of your vehicle.
? For the following example, the combined weight of occupants and cargo
should never exceed 865 lbs (392 kg).
Thanks again for your email.
Sincerely,
Tony
Customer Service Representative
FCA US Customer Assistance Center
For any future communications related to this email, please refer to the
REFERENCE NUMBER: 26474988
EMAIL CASE NUMBER: 3109218
REPLY LINK:
http://www.chrysler.com/wccs/brand_f...133V56165L0KM&
