Actually, Dicor provides that stuff:
http://www.forestriverforums.com/for...or-163491.html
"Had some warranty work done for a leak in the air lines at local Freightliner shop back in November. Had them re-torque the wheels. Took a short trip later in the spring and drove with the windows down and heard a clicking noise from front wheels. Two trips back to FL and still clicking. BC gave me a point of contact with FL and he suggested taking off hub caps and seeing if that was the problem. It was; the 2 retaining nuts were too tight. This had been done when wheels had been re-torqued and each time they worked on the clicking noise. I put them back on a little looser. Guess too loose because I lost one; will use locktite now. Found out the wheels are supplied by Dicor. (Danielle Sodeman, Dynamax parts: "Dicor Corp supplies the wheels to us the part #is VAC10285-F1422")
I ordered two nuts/covers from the Dicor website but the ones I received were two small. Called and got the right ones coming. The correct parts were not listed on the website. No charge for the correct ones and told to keep the others as they fit the rears. Great customer service from all.
FYI:
Part #V22506-RJN for jam nut, front
#V22506-LNS for acorn cover, front.
Part #V19582-EJN for jam nut/cover combo, rears."
