Closed Thread
Old 08-01-2020, 12:09 PM   #1
Why you MUST use slide out locks - Video from what happened to me
This happened on the way back from when i was picking up my DX3. There was a lot of wind, but in the DX3 of course i barely noticed it.
The wind was coming across the road from drivers side to pass side. When i opened the drivers window it created high pressure in the coach and low pressure on the pass outside of the coach causing this. It was scary!
https://youtu.be/25KxOQbR0gA
Needless to say, I kept the window closed and as soon as i got home i ordered some slide out locks!
I should add this is no fault of Dynamax, as just about any coach would do this...the slides are not secured at the top. Throw in a few slide out locks or even chunks of wood and you will never have this issue.
johndjmix is offline
Old 08-01-2020, 12:50 PM   #2
I’m curious
Wow that’s nuts what pressure change can create. When you have the slide in at home can you easily push top out or is it pretty solid. I have a TT I need to use slide locks on and the front top off slide pushes out pretty easily.
Enjoy your new rig.
2020 Flagstaff 26FKBS
2020 Ram Tradesman 2500 6.4 Hemi
Csbadvisor is offline
Old 08-01-2020, 01:02 PM   #3
Think I’d be contacting the manufacturer and see if it should be doing that. Seems to me something is awry.
phipps33 is offline
Old 08-01-2020, 01:06 PM   #4
mjbenedict's Avatar
Does yours just have the motor at the bottom?
2020 Dynamax Isata 5 36DS 4X4 (Super C)
2020 Ram 1500 Limited
Sold: 2015 Rockwood Ultralite 2604WS
No longer mine: 2006 Rockwood Roo 23SS
All pop-up and tent camping before...
mjbenedict is offline
Old 08-01-2020, 01:43 PM   #5
Guys, its not the MFG's fault at all! This is how just about all slides are made...they slide at the bottom, the top is not secured.
This is why they make slide locks! Use them!
FYI, when this did happen, it caused no damage...thanks to the well built strength in the slides. So if anything I need to thank Dynamax for the strength!
--John
Old 08-01-2020, 01:51 PM   #6
This doesn't sound normal to me. I never use slide locks and the slide doesn't move at all. I normally worry the slide moter will fail and then no easy way to move the slide.
NearDenver is offline
Old 08-01-2020, 01:52 PM   #7
--John
I disagree. This IS the manufacturer’s fault. If this slide tipping happen with RV use on the highway, and slide out locks are the solution to this problem, then the manufacturer should have provided the slide out locks with the motorhome and instructed the customer on their use.
All slides are not made this way. Our motorhome is not a Dynamax, but the slides are secured at both the top and the bottom.
2020 Sunseeker 2440DS on 2019 Ford E-450, Trekker cap, Topaz paint
BehindBars is offline
Old 08-01-2020, 01:56 PM   #8
8 years with my Fleetwood pusher it never happened....then it happened on the fleetwood. Once in 8 years. Just happened to be the first trip in the DX3 that this happened.
It only happens on VERY specific conditions. I agree MFG should include slide locks, but keep in mind EVERY SINGLE slideout made can do this...its just a matter of "the perfect storm" happening. If you go and stand in the coach and try to push the slideout by hand you cant. The power of air pressure is what you are seeing.
Im not aware of any slideout that has a top mechnism that stops this from happening so pretty much every MFG should include slide locks.
But, as said....this is a VERY rare situation. Google it and you will see it happens across all brands in that specific situation.
--John
Old 08-01-2020, 01:57 PM   #9
Can you show me a picture of how the slides secure at the top? I have never seen such a system and would be curious how this is done.
Old 08-01-2020, 02:20 PM   #10
Below is at least one system used that holds both the top and bottom of the slide. It is not a photo of my camper, but it shows a Schwintek in-wall slide system. There is a motorized shaft that runs vertically inside the wall, on each side of the slide, with a gear at top and bottom, meshed with the respective gear racks. The slide top always moves in sync with the slide bottom. Sometimes on heavy slides there are two upper racks and one lower rack on each end of the slide. The only way the slide could tip out is if the system was broken, and the gear possibly spun on the shaft or disengaged from the rack.
ID:	235328   Click image for larger version
ID:	235329   Click image for larger version
Old 08-01-2020, 02:24 PM   #11
Very Cool! I havent seen a system like that, seems like every slide should have it! Thanks for enlightening me on this!
If you dont have that kind of a system, use the slide out locks!
--John
Old 08-01-2020, 02:36 PM   #12
--John
Well, not everyone loves the LCI Schwintek system. The concept is great, although I hear it can have it’s problems, but the slide tipping out on the highway is not really one of them.
Old 08-01-2020, 02:59 PM   #13
--John
If all manufacturers put slide locks in place I guarantee you with. A week there would be 50 warranty claims from folks who opened the slide with the locks in place.
OTOH...won’t happen on a Forester.
BIRDS AREN’T REAL
emm-dee is offline
Old 08-01-2020, 03:30 PM   #14
Looking at the video again, I am in awe that an RV design allows a slide out to tip out to that extreme while going down the road. Is this slide design used by all Dynamax motorhomes, and would some or all potentially tip out like this under the right conditions?
This looks potentially like an NHTSA reportable issue. https://www-odi.nhtsa.dot.gov/VehicleComplaint/
Old 08-01-2020, 04:57 PM   #15
TrailWayz's Avatar
Wow! What a champ the way you are handling this. That looks extremely scary to me - and very problematic. Glad you posted this. What an experience.
-Brian
2020 Isata 5 30FW 4x4
2019 Jeep Grand Cherokee Summit
TrailWayz is offline
Old 08-01-2020, 06:58 PM   #16
jneum525's Avatar
Does anyone have a picture of a slideout lock? I've never heard of such a thing. How do they attach? Are they needed on the Isata 3?
Had my old motorhome for 20 years and drove it in very heavy winds at times and never experienced anything like what I saw in the video in the initial post.
2017 Isata 3 24FW (Purchased Feb '20)
jneum525 is offline
Old 08-01-2020, 07:37 PM   #17
milkman55's Avatar
The slides with the hydraulic mechanism underneath the slide would be susceptible to what we saw in the video. The Isata 3 and Isata 5 have the gears at top and bottom.
Here is a slide lock. It is not needed in every circumstance, but certainly doesn’t hurt anything unless you forget to remove it before you operate the slide. In this picture, I don’t think it was a coincidence that the slide lock was installed at the top of the slide.
2021 Isata 5 30FW
2022 Ford Ranger Tremor 4x4
(Previously owned a 2017 Isata 3 24FW)
milkman55 is offline
Old 08-01-2020, 07:40 PM   #18
jneum525's Avatar
Thanks Milkman. Much appreciate the education...as always!!!
jneum525 is offline
Old 08-01-2020, 08:03 PM   #19
Herk7769's Avatar
Slide locks in my previous camper.
The gearbox has a slip-clutch to prevent binding up the gears. When you run the slide all the way in or out, you can hear it slipping.
A sharp sideways lurch (like a hard curb strike) can also let that clutch release and once that slide starts moving it can run all the way out due to inertia.
Name:	Camper Slide Braces 001.jpg
ID:	235378   Click image for larger version
Name:	Roof Shots and others 025.jpg
ID:	235379   Click image for larger version
Name:	Camper Slide Braces 005.jpg
ID:	235380   Click image for larger version
Name:	Horst Probe Install 024.jpg
Herk7769 is offline
Old 08-01-2020, 08:05 PM   #20
WHOA! Uh, really! I hope for all you Dynamax owners that this is not something that can happen to you.
A while ago a watched a dealer video of I think what was a Newmar or Tiffin that had electric locks on their slides.
Magnatudes is offline
Closed Thread
lock, slide, slide out
