Old 09-28-2020, 08:52 PM   #1
Hardhead417's Avatar
Winter storage
In the past I have been able to keep my campers plugged in over the winter. However, this year I have an Isata 3 which is my first Motorhome. I donít have any problems with winterizing, but my question is about the batteries. The unit is stored inside without power available. The battery isolation switch still leaves some draw on the house batteries. Should I periodically charge the batteries or is it ok to allow them to drain. From what I understand that can reduce battery life.
2021 Isata 3 24FW
Hardhead417 is offline   Reply With Quote
Old 09-28-2020, 09:33 PM   #2
milkman55's Avatar
You definitely do not want the batteries to drain. Disconnect the battery cable, pull the batteries out to store at home, or use a battery disconnect on the negative terminal like the one below.
https://www.amazon.com/Post-Battery-...1346671&sr=8-3
2021 Isata 5 30FW
2014 Honda CR-V
milkman55 is online now   Reply With Quote
Old 09-29-2020, 03:44 AM   #3
JC70's Avatar
^^2^^
Sheila and Joe
2020 Force 34HDKD - XLRB next March
2016 Jeep Grand Cherokee
JC70 is online now   Reply With Quote
storage, winter
