I'm installing a new Power Cord 'powered' reel. I bought an inline fuse (20amp) and a 20amp circuit breaker. First I install a short piece of red wire to the positive terminal on the battery that has another small wire (supply from the solar I think). Here I attach an inline 20amp fuse to protect the long wire from fraying and such? Then from that fuse I run the red wire all the way across the coach to the cargo bay where I've installed my reel. There on the bulkhead I install the 12v 20amp circuit breaker. Red wire from battery in (does it matter which terminal?) and on the other side the red wire from the motor switch. Then I take the black wire from the motor switch and attach it to the frame with one of the screws holding the plastic tub in the bay. I presume this screw goes into the steel frame. That should do it?
What gauge red wire for the very long run, 12 - 15 feet or so? 10 gauge? 12 gauge?
Thanks, not an Electrician Mate.
