Xantrex Help
Just had a new Xantrex inverter/charger installed in my 17 I5. Had to replace both the AGM unit in the basement, the display head in the coach and even the cat 5 cable was faulted and replaced.
I thought the mobile tech got everything replaced and programmed correctly but the two battle born batteries will not charge with the generator or the solar panels.
They will charge via shore power or with the alternator when the engine is on.
Is there a setting that he missed while programming the Xantrex unit or is there another component that may have been damaged?
Rob & Rosanne Rzasa
2017 Dynamax Isata 5 36DS
Towing 2005 Honda Big Ruckus
Go Gators
