Originally Posted by bama_shiner
Hello,
New to the forum, new to RVing, and have a question. Just purchased a 37FBT and looking to upgrade the suspension. I am wanting the morryde cre3000 and the shackle upgrade kit. Does anyone happen to know what the correct part numbers are for these?!?! Just to keep me from having to crawl under and measure as I am a disabled veteran.. I just upgraded to the morryde pin box and need to finish it all out...
Thanks in advance,
Bama
Unfortunately, Forest River does not publish the wheelbase of any of the Sabre fifth wheels. We need to know if the FBT wheelbase is 33, 35, or 42" before anyone can determine the correct CRE3000 equalizer part number.
33" wheelbase - CRE2-33
35" wheelbase - CRE2-35
42" wheelbase - CRE2-1000
Chances are highly likely the FBT wheelbase is 42", but would recommend measuring to be sure.
The heavy duty shackle kit you're going to need is also dependent on whether the ones on the FBT are 2-1/4" or 3-1/8". Again, chances are the ones on the FBT are 3-1/8", but recommend measuring them to confirm.
Unless Forest River has changed, the FBT always came with standard hangers, so below are the corresponding Morryde shackle kit part numbers.
2-1/4" shackles - UO12-016
3-1/8" shackles - UO12-021
You can download the CRE3000 Qualification Guide to assist you with the needed measurements at the following URL:
https://www.morryde.com/wp-content/u...-Qualifier.pdf
