02-09-2021, 02:17 PM
#21
even purchasing one for your trailer and planning to install it yourself may not go as planned.
when a ladder is installed at the factory there are beefed up supports internally to support the ladder and the intended limited weight
without it you are merely drilling through the roof membrane and the thin roof decking and on the end of the trailer the gel coat fiberglass.
if they haven't installed the ladder they most likely haven't installed the support mechanisms as well.
TV 2018 Ford F250, hauling a 2018 KZ 331 TH 12 Sportster 5th wheel, packing a 2015 CF MOTO 800 U-Force SXS
02-09-2021, 02:18 PM
#22
I'm not so sure I'd install a ladder on an RV that doesn't have one nor does the manufacturer install them anymore. This could have a waterfall effect in an effort to save money. What ladder would you buy, how would you find out what to attach it to so its secured enough to use it without ripping it out of the frame and causing permanent damage to your RV? And how would you know even if your were able to attach it down the road it wasn't leaking until its too late? I, like previously mentioned, have a telescoping ladder that is also rated for 300 lbs. and IMHO is safer than any attached ladder. Being a new RV would add to a caution that it could and I say could void the warranty if a leak developed on the roof or sides. They'll use that as the reason it wasn't designed for it...that's my two cents. I'm sure you'll hear from others that have done it without any issues.
Dana & Terri - (Retired)
Our Cocker Spaniel "Shadow" (6 y/o)
Stephanie (daughter)/Rick/Callie (14 y/o)
Great Granddaughter - Cora (2 y/o)
Great Grandson - Zek (1 y/o)
Phillip (son)/Charlotte (6 y/o)
02-09-2021, 02:32 PM
#23
Have we determined if what the dealer said is correct? Do they no longer install roof ladders?
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
#24
Design Change?
Make sure there hadn't been any design changes to the roof. Long time ago, had a Scotty trailer that didn't have a ladder. Dealer told me there isn't any plywood sheathing under the rubber roof (and that was true). Maybe the roof can no longer support walking on it. Just my $.02
02-09-2021, 02:33 PM
#25
Originally Posted by TitanMike
Can't count the times I've been injured due to my own stupidity. Fortunately only causing physical discomfort. but never has the thought passed through my mind i should retain a lawyer to make someone else pay for my dumb actions.
It amazes me how people think that their misuse of a product is the manufacturer's fault.
We have a local radio talk show host that has a segment on his show called 'Signs the End is Near". He reads from news reports of cases where people do stupid things with disastrous results. Sad, but entertaining to a point.
Yep, sounds just like the 6pm local and national news stories of the day.
2020 Forest River Sabre 37FLH
2013 Ford F-350 XL Crew Cab 6.7L Diesel DRW
Tulip, the Wonder-Shepherd
02-09-2021, 02:40 PM
#26
Originally Posted by Tonylmiller
You may be correct, but I'm going to let EVERYONE know about their misleading advertising.
Go right ahead. You're off to a good start. It's likely that almost nobody cares. Are you really telling us that you would not have purchased this RV if you had known it did not come with a ladder?
2018 Coachmen Leprachaun 210RS with DW, Nanuq the Samoyd puppy and the cat.
02-09-2021, 02:46 PM
#27
Before you put a ladder on you’d best check to make sure the wall can handle it. They may have taken the supports out also.
2017 F150 XLT 3.5l Eco Boost, SC, 8' Box, 4X4
Max Tow (10 speed, 3:73, 11,700lbs), HD Payload (2440lbs)
2015 Puma 253 FBS
2013 Hyundai Santa Fe
2000 Honda EX 400, Rad Rover 6 Plus
02-09-2021, 02:54 PM
#28
Originally Posted by GPs37FLH
However, according to OSHA requirements, "Each step or rung of a fixed ladder must be able to support a load of at least 250 pounds (114 kg) applied in the middle of the step or rung. Minimum clear distance between the sides of individual rung/step ladders and between the side rails of other fixed ladders must be 16 inches (41 cm)."
Interesting to know, but it occurs to me that I have never been concerned with the step breaking, but with the whole damn thing pulling off the back of the RV while I'm climbing it. Anybody know if there is a standard for that?
02-09-2021, 03:26 PM
#29
Too many old, fat men falling off the ladders and the legal department made a call. No more fat men on the roof via ladder.
Have fun
02-09-2021, 03:33 PM
#30
Have fun
Quick solution so the old, fat farts don't fall off the roof during annual inspections anymore?.....Drones!
02-09-2021, 03:38 PM
#31
My solution when I don't want to climb the ladder anymore will be to get my granddaughter to do it. She's picky and if things don't look right she can take a picture and bring it to me on the ground.
02-09-2021, 03:43 PM
#32
Kids and grandkids work pretty good too, Mike . Thanks for reminding us!
02-09-2021, 03:46 PM
#33
As a 66 year old retired firefighter, I still have no issues with ladders. But last year I fell 15 feet off my ladder, onto concrete, while cleaning gutters. My head missed a huge boulder by mere inches but somehow all I got was a few bruises.
So it hasn't deterred me from getting on my TT's roof, which has no ladder. And I weigh 235lbs, due to Covid![emoji1787]
02-09-2021, 03:50 PM
#34
......Nice!
02-09-2021, 04:18 PM
#35
02-09-2021, 04:35 PM
#36
Originally Posted by Brickie
I assume they're adding the roof rack to the 2021 and a half model year? So much for what the dealer said.
02-09-2021, 04:39 PM
#37
ARLO
I just got a new 37FLL. It did not come with the ladder installed on the rear of the camper. When I inquired about this, the dealer told me that Forest River will not install them anymore. Even though all of the sales materials still show ladders as being standard. Needless to say, I am not a happy camper. I have submitted a question to Forest River about this situation. Basically I told them that they are misrepresenting their product and they should pay to have a ladder installed on my camper
PARTS AND DESIGN CHANGES: Warrantor reserves the right to change the parts and design of its recreational vehicle from time to time without notice and with no obligation to maintain spare parts or make corresponding changes in its products previously manufactured.
02-09-2021, 05:13 PM
#38
ysidive
Maybe you should go after the dealer for not informing you before the unit arrived... Maybe you could have negotiated the ladder from the dealer... If he sold it to you with the understanding that a ladder was part of the package, then he should install it free...
2018 Duramax 2500 LTZ
Freedom Express 281rlds
Days Camping 2021 46 Days
Days Camping 2022 Not Enough
02-09-2021, 05:57 PM
#39
I just did a nationwide search for this model on RV Trader's website. As of today, there are 77 listed for sale. Of all the ones listed with non-stock photos, there were two that didn't have a roof ladder.
Either the Sabre manufacturing plant ran out of the ladder assembly before these units rolled out the door (which is possible), or they didn't come with Forest River's roof ladder package.
Its just like the Juice Pack that all Sabre's are supposed to include. There are some manufactured without this option, but their asking price is also about a grand less. I noticed this when I bought my Sabre last year. The dealer had photos of multiple FLH units for sale, some without the Juice Pack. The dead giveaway to determine if they had it or not, was whether there was a volt meter installed in the control center area. When they told me the one I bought included the option, but the photo of the one with the stock number I bought didn't include the meter, I had them take a picture and text it to me to prove it before I signed any paperwork.
Buyers beware!
02-09-2021, 07:43 PM
#40
Happy Camper
Buyer beware, indeed!
2021 Forest River Sabre 37FLL
Towed with 2019 Silverado 2500 HD
B&W Turnover Ball Gooseneck hitch
Anderson Ultimate Connection 5th wheel hitch
