Hisense frig
Our double bottom freezer frig is having temperature issues. The freezer works fine, but the frig temp varies from 25 degrees on bottom shelf to over 50 degrees on the top shelf. I have tried numerous things to alleviate the problem.
Installed rechargeable fan on bottom shelf, ran frig almost empty and almost full and spread everything out. The fan helped but was a pain. Is there an internal circulation fan for just the frig? And if so where is it and how do you get to it. Any thoughts on this issue would be appreciated. Frig is a hisense french door double bottom freezer in a 2019 Sabre bhq. Thank you in advance.
