04-02-2022, 11:32 AM
How to connect prepped outlet
I just bought a 22 Sabre 37flh and 110v outlet in w/d closet is just prepped but no actual outlet. Do I just pop the cover off and connect a outlet and find the space for a breaker panel?
Thank you in advance.
04-02-2022, 11:50 AM
Have you checked with your dealer? It may be the work was overlooked and not completed.
2015 Dynamax REV 24TB class C
04-02-2022, 01:00 PM
Happy Camper
Yes it should be there.
At least it is in my 37FLL.
But of course, Forest River reserves the right to change or delete features without notice, such as ladders.
2021 Forest River Sabre 37FLL
Towed with 2019 Silverado 2500 HD
B&W Turnover Ball Gooseneck hitch
Anderson Ultimate Connection 5th wheel hitch
04-02-2022, 01:02 PM
New here, old elsewhere
Depends, if the wiring is in there and "hot" yes on the outlet, no on the panel. If the wiring is there but not hot, yes to both. "Only you can tell us the answer"! /end Smokey Bear voice.
2021 Coachmen Apex Ultra Lite 253RLS
2016 Silverado 1500 Crew Cab Z71 / 6spd / 3.73
04-03-2022, 07:52 AM
Our FLH came wired and ready to go. We use the outlet with our portable dishwasher that's sitting in that closet. You will find one of the breakers marked for the washer/dryer in the panel in the kitchen.
As recommended, you can call the dealer from which you bought it, but they'll most likely have no idea and tell you they need to have you bring it in. If it were me, I'd remove the outlet cover and install an outlet there. I'm certain the wiring's there and you'll do a better job than the dealership.
2020 Forest River Sabre 37FLH
2013 Ford F-350 XL Crew Cab 6.7L Diesel DRW
Tulip, the Wonder-Shepherd
04-03-2022, 01:37 PM
Our 2021 FLH also came with outlets, just no dryer vent until the dryer was instlled.
04-03-2022, 02:27 PM
Unless you don't know anything about such things, learning electrical service can be a shocking experience!
04-04-2022, 07:21 AM
Very true! I'm of the belief "give a man a fish and feed him for the day, teach a man to fish and feed him for a lifetime". A quick Internet or YouTube search on the subject can help to educate one on how to do this. Can't tell you how many things I learned from Internet or YouTube searches about the many upgrades and fixes I did to my RV over the last couple years. Not only did I learn something new, but had the satisfaction of getting it done myself, doing a better job than a dealership, and saving time and money in the process.
04-04-2022, 12:50 PM
You realize...
You realize, don't you, that RVs don't use the junction-box-and-screw-terminal-outlet that are used in residential and commercial construction?
They use a special Self-Contained Device (SCD) outlet. It simply clamps over the NM cable and connects via "insulation displacement." This usage is approved by the National Electrical Code. Here's the brochure on it.
Another brochure
You can get the special outlet at Amazon.
https://www.amazon.com/RV-Designer-S...9092799&sr=8-5
https://www.amazon.com/RV-Designer-S...9092799&sr=8-6
https://www.amazon.com/Diamond-Group...9092799&sr=8-7
Also at eBay.
The special tool shown in the brochure costs several hundred dollars. shows use of the Hubbell tool.
shows how to make a tool by sacrificing an outlet.
I've read of others using a screwdriver as a punchdown tool. That would be my last resort.
Larry
04-04-2022, 08:04 PM
Thank you for inputs. I popped the cover and it seems it’s prewired but still have to find the breaker. Fifth wheel still at dealer so I can install it later but it’s rated at 10amp and washer/dryer I am looking at is 13amp…
04-04-2022, 08:14 PM
Buying w/d is another issue. Good dryers are 240v or gas…
My choice right is LG all in one( 110v, ventless and easy way out) or stackable and convert the gas dryer to propane…
I’m trying to squeeze in as big a w/d I can.
04-04-2022, 09:05 PM
More info
Here are 15-amp SCD outlets.
It won't be much comfort to you, but here is a link to a much less expensive SCD punchdown tool. It looks like you press the conductors into the retainers one-at-a-time.
Less expensive outlets here.
Larry
04-05-2022, 07:31 AM
You'll find the the panel by the door. It's a 20Amp breaker in the panel set aside specifically for the washer and dryer and includes what appears to be a circuit test button. Both are on the same breaker and is the fifth breaker from the right side, just in case yours aren't labeled.
04-06-2022, 09:10 AM
Thank you for inputs and upon further review, I think it’s best that I turn the prepped outlet to standard house outlet. There doesn’t seem to any safety issue(probably better to have household outlet with very small point of contact with SC outlet) and as things fall apart, I was going to turn them into residential items anyway. Fifth wheel is going to be stationary.
