09-17-2017, 08:53 AM
#21
Long bed short bed
Not only will you not have to buy a special hitch but the ride is much better afriend has a 3500 dodge dually short bed and it rides like a tank we got back in our F450 long bed and it felt like riding in a caddy
09-17-2017, 08:59 AM
#22
Originally Posted by DouglasReid
There I Was, agreeing with this guy until he made the above statement. I DO NOT agree with that!
I tow a 35' 5er, 12200 GVWT and drive an 08 Chevy 2500HD CCSB 2wd. After going through a CAT scale only last Thursday, Fully Loaded on our way camping this weekend I learned Im about 2000 lbs (1 ton) under GVWR and 2000 under GCVW.
Would a 1 ton truck provide a bit more "cushion"? Yes. Is it necessary, NO!
Really? With my 2008 2500HD CCSB 2wd (Duramax and Allison tranny) and a 9,300 pound 5th wheel, I max out my GVWR of 9200 pounds (pin weight of 1600 pounds) while at 7,000 pounds under GCWR.
I totally wish I had gotten a 3500HD.
Here is my worksheet from a trip to the Keys and you will see what I mean.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
09-17-2017, 09:24 AM
#23
I guess I've never gotten the "It's my daily driver" argument. Well, somewhat........if you are commuting long distances, I guess. And one thing that hits me on these discussions is the difference between those still working vs. retired. If you are working and trying to balance 9 things, I sort of get that. I remember that. LOL
But if you go camping for a week, whatever your truck is, it's your 'daily driver' for that week, isn't it? If it can be your daily driver for that week, why not every week? What is it about long beds and duallies and such that everyone can drive while towing but somehow can't otherwise? I haven't driven anything else but a dually since I left July 31......and won't till October. I park it anywhere I want, I park it in driveway, I go here, I go there. What is it I can't do??
I do know ONE thing! I have never, ever, EVER been towing this 15,000 lb behemoth and turned to DW and said "Boy, I wish I had a smaller truck".
FROG AR-0019-242
09-17-2017, 02:33 PM
#24
Long bed vs short bed.
Thanks for all the input, a lot of valuable information.
09-17-2017, 03:06 PM
#25
Herk, that payload is worse than my F 150 Ecoboost was.
09-17-2017, 03:10 PM
#26
How much do tires cost?
Dually cost for tire rotation.
Dually are not worth a crap in snow and slush and ice when they are loaded.
I have 16,000 lbs and am quit happy with my SRW and 3700 lbs of CCC with no air bags or compressor to fail with snow, ice and salt on the roads.
Daily Driver means different things to different people.
09-17-2017, 03:39 PM
#27
Remember remaining payload left for pin is GVWR minus truck "loaded for camping". The short bed's teeny tiny fuel tank is augmented by 12 gallons of diesel in cans. Then add family, hitch (that slider is heavy), generator and 2 1/2 gallon gas can, some shoring, that honking diesel engine and monster trans, and there you are.
10-05-2017, 04:26 PM
#28
We have a Ram 2500 with Mega cab, which means a super short bed. We just purchased a fifth wheel that has the angles nose cone and installed a slide hitch. So far after 3 trips we haven't had to engage the slide at all and have quite a bit of clearance. We also made some pretty tight turns. We are really happy with the set up. I would post a pic, but not sure how. :/
10-10-2017, 02:08 PM
#29
long or short
I recently rode in a short bed 1 ton dually rode like a tank I got back into my F450 long bed and it felt like riding in a caddy. short bed bad!!!
10-10-2017, 02:36 PM
#30
Actually a dually short bed is nothing I see a reason for. As I got older I swore off both a dually and long bed. I simply keep my 5ers within spec of an F350 short bed. Still need a step stool to put the lock 🔐 on the 5er hitch and rarely use a boat hook to reach something in the bed. Older with a bad back and paratrooper knees means a little change in a few areas.
02-15-2018, 11:13 AM
#31
I have recently done a lot of research on this and like everyone is saying, it really depends on preference and how careful you are. That being said, it is also very dependent on your truck, pin box, and nose cap of your fiver.
I have a F250 CC SB with out the factory puck system. I installed custom rails and bought a slider hitch which I have/will use whenever I am going to be in tight situations.
The Ford short beds are 6.5ft whereas Chevy and Dodge are 5'7"; that 10inches makes a huge difference.
With more modern fifth wheel caps the corners are set back from the pin box/kingpin in such a way to provide more clearance.
So it really all depends. I bought the slider and will use it because the 2 minute it takes to slide it back is a lot cheaper than replacing the back window or cap. And I am in no hurry with something this big!
matt
02-15-2018, 11:35 AM
#32
Originally Posted by Matt_Lewis
I have recently done a lot of research on this.....
Incorrect/misleading statement. You need to do some more research
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
02-15-2018, 12:01 PM
#33
Georgia Rally Coordinator
matt
Seeing how you not a chevy guy here are the correct bed lengths for Chevy. Chevy box sizes are 6.5ft and 8.0ft. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
02-15-2018, 01:06 PM
#34
I did google 'chevy short bed length' and according to wikipedia:
Chevrolet_Silverado#Bed_Lengths
Silverado/ Sierra has 3 bed lengths. Short Bed= 69.3"/5.775', Standard Bed= 78.7"/6.5583', and Long Bed= 97.6"/ 8.1333'
Thank you for clarifying though.
matt
02-15-2018, 01:10 PM
#35
The 6' 5" bed is termed a standard bed for the Silverado.
02-15-2018, 01:29 PM
#36
After doing a little more research, I agree...though admittedly not a truck guy period, even on the GM fleet website it is confirmed there are 3 different bed offerings.
SB = Short bed, which is what I was referring to in my original post is indeed 5.7ft.
Maybe I wasn't the one who needed the extra research after all!
matt
02-15-2018, 01:42 PM
#37
This is why I ALWAYS suggest people use lengths in feet/inches instead of words such as Short, Standard, Long, etc.
02-15-2018, 01:46 PM
#38
matt
I was going to tell you how wrong you were, I see others have already done so, no need piling on!
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
02-15-2018, 01:59 PM
#39
Wrong on Ford too. SB is 6 3/4' not 6 1/2'. 4" make a difference?
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
02-15-2018, 02:18 PM
#40
Sorry to be an #$% but anything less than a long bed is not a truck and useless.......... (to me and for my use) It would be a cold day if I ever own anything less than an eight foot bed.
On a more serious note it depends on your needs........................
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
