Check Valve/Vacuum Breaker
The problem you had was your check valve for the black flush got stuck and water came out of the vacuum breaker relief port. When you turned the water off, everything in the check valve went back into place and fixed itself. The next time you used it, it didn't leak. It may never happen again, but keep your eyes on it.
Bruce
