Old 09-13-2022, 12:34 PM   #1
Suburban heater/furnace
My sf-35q heater won’t put out heat after replacing the limit switch and the sail switch. Any ideas?
[SIGPIC][/SIGPIC
2016 Ram 2500 Cummins
2015 Sabre 292rlds 5 th wh
2014 45 nights
2015 51 nights
2016
Dsweet is offline   Reply With Quote
Old 09-13-2022, 01:01 PM   #2
What caused you to replace limit and sail switch? First thing that happens is the blower runs, does it?
Capacitor is online now   Reply With Quote
Old 09-13-2022, 01:07 PM   #3
The fan comes on with out any heat. It tries to ignite, but goes out immediately.
[SIGPIC][/SIGPIC
2014 45 nights
2015 51 nights
2016
Old 09-13-2022, 01:08 PM   #4
https://thecampingadvisor.com/suburb...oubleshooting/
Old 09-13-2022, 01:15 PM   #5
Thanks. I'll check it out.
[SIGPIC][/SIGPIC
2014 45 nights
2015 51 nights
2016
Old 09-13-2022, 01:57 PM   #6
I'll ask this too.
Those parts aren't maintenance items so there was a reason you replaced them.
Give us the whole story and we can give better answers.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 09-13-2022, 03:04 PM   #7
Well, the sail switch works as you got this far in the sequence. Next is the gas valve opens and igniter sparks, gas lights and igniter sends a flame proving signal back to circuit board telling it to stop the clicking and hold gas valve open. This is where the failure is. Possible corroded ends on igniter not allowing signal back ( milliivolts) or weak connection with spade clip on igniter. Clean igniter with emery cloth or coarse sandpaper. Check gap 1//8 to 3/16. 1/4” nut driver and carefull with the gasket.
heater, suburban
