Originally Posted by funky40
Can someone assist please. I've look where the fresh/gray water is but nothing there. I've looked all around underneath, nothing. the only other place it could be would be where you an winterisze??? Didn't look in there wanting to drain tank and also test with fresh water. but not finding. any help would be appreciated
The low point drains are not what you use to empty the fresh water tank.
There is a 1/4 turn valve located in the compartment with the water pump, filter, winterizing port, etc. Use that valve to drain the tank and use the low point drains when winterizing or if sanitizing the entire system.
As mentioned above, the low drains are just rear of the entry step and you will need to get on your back to get to them.
Happy Camping!
