I've searched the forum and see a few posts on issues with pre-installed solutions, but has anyone added a manual jack for stabilizing their MB3500 chassis RV?
I'd like to reduce the side to side motion when walking around inside or entering/exiting the coach. Currently I use a Valterra 020106 RV Stabilizer under the rear bumper which helps a little...
I have them installed on front and rear plus a Helwig anti sway bar - they help with driving, but don't stop the motion when parked on a 11.5' tall RV.
One of the first things I did to my 2150LE was to put manual "Stabilizers" on the back of my rig. I fashioned two stiff aluminum angle brackets to fit on the rear frame extension bolts and a set of scissor jacks to crank down with a hand drill. https://www.amazon.com/Eaz-Lift-Stab.../dp/B00IKKS4W8 Stops the rocking of the rig while parked and walking around inside. I am seriously looking at automatic hydraulic levelers. Challenges Cargo Carrying Capacity though...
I was considering scissor or "C" jacks as well. I don't really want the expense of the hydraulic levelers nor the loss of CCC either. These are the two options I'm considering, but everything is on hold until spring since I'm in the Albany, NY area and it's cold with snow at the moment...
saw a video on YouTube from a guy named "Grandpa Ron" who is a retired engineer running a Winnebago View on MBS3500. He picked up some cargo stabilizer bars from Harbor Freight, cut them down a bit and braces under the rear wheel well to create outriggers - looks like a simple, low cost effective solution...
