Old 10-31-2020, 08:07 PM   #1
2018 Sunseeker 2400W MBS
Iceman from McMurdo's Avatar
Best Seat/Lid Combo for Thetford Toilet?
Okay folks, I just upgraded the OEM plastic Thetford toilet in my Sunseeker MBS 2400W to a nicer porcelain bowl model (Thetford Aqua Magic Style II) and now trying to find a better seat/lid combo than the original cheap plastic it came with. Initially posted this in the plumbing forum, but nobody answering me there, so starting a new abbreviated thread here for fellow MBS owners.
Ideally, I'd like to find a nice enameled wood (or at least solid surface plastic) slow-close model if available. Biggest problem I'm finding is locating something in the correct color, as I elected to go with the original "bone" color of the original unit in my coach. Neither Thetford or Camping World were of much help, and after checking around at the big box stores I could find nothing in BONE color that fit acceptably.
After many hours of internet research, finally got some leads on two potentially better-fitting candidates in the BONE color I need:
The Bath Royale BR620-02 seems to have the most positive reviews associated with actual RV use. It's a much heavier-duty plastic seat with smooth underside that features the soft-close I want and also a hinge design that allows for better fore-and-aft adjustment to better fit the Thetford's bowl design. It's available at Amazon for about $50.
The Mayfair 847SLOW 006 Kendall appears to be another possible option and is less expensive despite featuring an even stronger enameled wood seat AND the soft-close option. It too offers fore-and-aft hinge adjustment and is avail at Amazon for only $35.
I'm sure there are others here who might have been (or are?) in the same situation I'm in, so would be VERY interested to hear from anyone who's actually installed one of the above seats (or others?) on a Thetford Aqua Magic Style II, so they can share their opinions with us (good OR bad) about the quality & fitment of their selection. THANKS!
PS - I know many are likely to suggest just switching to the Dometic 320 which comes with a slow close sea/lid already, but space limitations don't allow for the footprint & different water hookups that would require. Besides, the Thetford line has served me well so far and the new one is already in place - so a NICER and easier to clean seat/lid combo is what I need at this point. Anxious to hear if others have already solved this problem?
At the tender age of almost 70, I've learned the hard way that life is HARD... but it's even harder if you're just not very bright and FAIL to learn from your mistakes...
Iceman from McMurdo is offline   Reply With Quote
Old 11-06-2020, 12:46 PM   #2
Problem Solved
Well, surprisingly, I've received ZERO input on this topic - kind of unusual given the number of folks who have previously expressed so much interest in upgrading the cheap plastic toilets most RVs come with from the factory.
So, I went ahead and took a risk by ordering the Bath Royale model mentioned above (found it for an even lower price of $32 as an open box return item). Good news - it turned out to be a perfect color match for Thetford "bone" and the installation was super easy!
All-in-all, the new porcelain bowl toilet & upgraded soft-close seat make for a SIGNIFICANTLY enhanced bathroom experience. No more flexing & squeaking noises like the whole thing is about to fall apart underneath you, ha!
For those in the market, I HIGHLY recommend it!
Old 11-06-2020, 01:24 PM   #3
Just as confused as you
Scrapper's Avatar
Adding pictures might increase interest. As had been said many times on this forum, "Without pictures it didn't happen".
Richard & Jill
Old 11-07-2020, 12:24 PM   #4
TowPro's Avatar
I would like to find one that is 6" shorter. Wife's feet can't even touch floor sitting on the can because FR mounted so high off floor
TowPro is online now   Reply With Quote
Old 11-07-2020, 12:43 PM   #5
Shorter "Low Profile" Version Also Available
Thetford DOES make a shorter "Low Profile" version of the Aqua Magic Style II that is lower by about 5 and a half inches. You might want to check that one out.
Old 11-08-2020, 08:34 AM   #6
I just built a little platform for the floor of the bathroom.
2015 Solera 24R
2014 Mercedes Chassis
DaveJordan is offline   Reply With Quote
Old 11-08-2020, 04:14 PM   #7
TowPro's Avatar
That's an idea. And it could be tall enough to put a hinged lid on it and store TP and bottles of blue stuff under it.
Old 11-08-2020, 04:23 PM   #8
bubbles's Avatar
Dometic's 311 and 321 are low profile versions of the 310 and 320 respectively.
Old 01-09-2021, 12:05 PM   #9
RVLifeIsGood's Avatar
I just need to replace the toilet seat and cover, but keep the original Thetford toilet that came with my Forester. (One of the hinges broke on original seat.) Wonder if the Bath Royale seat would fit the original toilet ... any one with experience replacing just the seat/lid combo? In meantime, will measure existing, and compare to the Bath Royale.
Kelly and MB
2017 Forester MBS 2401W Class C motorhome
RVLifeIsGood is offline   Reply With Quote
Old 01-10-2021, 09:28 AM   #10
TomAR's Avatar
Toilet seat hinge pin replacement.
The hinge pin broke on one side of my toilet seat. Numerous email conversations with them got me nowhere. On-line replacements were not right. I did find that a metric bolt (and nylock nut) fit perfectly; it takes some effort to get them into the tight space. Sorry but I don't recall the sizes (diameter or length).
2018 Sunseeker 2400R MBS (w/dinette)
2013 Honda CR-V toad
TomAR is offline   Reply With Quote
ford
