Also, the AC has to blow from it's cold air plenum INTO the Styrofoam channels (ducts) on each side. Sometimes the manufacturers don't make the opening from the AC to the duct large enough. I had low air flow on one side of my TT. I went in from the top (roof) and found only a very small opening from the cold air plenum to the street side duct. I cut some Styrofoam out and now I have better air flow.
This pic is looking down the duct from rear bath past AC to front. The light area on the right is light coming in through the opening to the AC's cold air plenum.
This pic is after I chiseled out some Styrofoam. You can see the light is a bit stronger, and you can see some of the Styrofoam laying on the bottom of the duct.
2011 Traverse LT, 3.6L, FWD
