Alas, my 2016 2400W has two compartments that are nested in the slide out and do not drain to the outside, a third compartment is rear driver side that is in main rv wall and over the Onan generator. All these compartment bottoms are the same floor material as main RV floor, not molded plastic, and do not have a plug. Any water intrusion drains into the main RV cabin. Three lower compartments are molded plastic with plugs and are fine draining outside. Just received the Challenger rubber seals...
