Dead battery and locked steering wheel
I had our 2017 Isata 3 in storage over the winter; I wasn't able to access it during that time. I do disconnect the chassis battery when I drop it off and leave a note for the staff on how to reconnect the battery when they need to move it. When I went to pick it up the staff had moved it to a parking lot. It started for me and off I went. I parked it for a few weeks and tried to start it today. I couldn't turn the key. Checked manual and online, found out I had a locked steering wheel and tried turning the wheel as I tried to turn the key. No luck. I tried the switch that connects the chassis to the coach battery; no luck. To confirm that the battery was dead, I tried to turn on the four way flashers; nothing. I did check near the gas pedal where the connection is to connect/disconnect the battery and it was loose. Firmly connect it and still no luck. I assume the staff at the winter storage place didn't make a firm connection. Enough to start it and get me home. Could a loose connection there lead to a battery drain? I will try to jump start it tomorrow; hoping the locked steering wheel will unlock and allow the key to turn and start her up. Anyone had a similor experience?
2017 Isata 3 on a 2016 Sprinter
