05-12-2022, 05:08 PM
Dynamax Service and Tire rotation requirements
I am a new clueless '21 Dynamax Isata 3 '19 Mercedes Sprinter Chassis RV owner. After one year and no information from Forest River, Dynamax or Mercedes on when and what service to have done I just took my RV into our local Mercedes Service Dept. after 11 months and 10,114 miles for service. Per a certified tech, a tire rotation should be done. The two rear steel rimmed inner tires were rotated and the two rear outer aluminum rimmed outer tires were rotated to the front on each respective side. The attached photos show the outcome. The now rear rims are pitted and black with what I assume to be brake dust from when they were on the front. Also one cap was broken when they took it off. I spent 3 hours trying to clean them and this was as far as I got. Is this normal or did I get taken. The service manager said I was responsible for both the cleaning and buying the new cap. Just doesn't sound right. Should I just have them put the outer tires back where they were. The rim finish looked like new when I took the RV in for service. Also, is there anywhere I can find a detailed list of what and when to do service like you would see and a car owners manual. Forest River, Dynamax and Mercedes national customer service centers all say the local tech's will tell me what is required. Just doesn't sound right. Thanks
05-13-2022, 04:50 AM
If your unhappy then have the wheels swapped back. Personally I have stopped rotating the tires . The fronts will wear faster, the rears will wear slower. The reality for most is that these vehicles are not your daily drive. The tires will age out and need replacement at 5 to 6 years for cracking/splits/dry rot before the faster wear on the front tires has to be addressed. Worst case you replace the fronts in 3-4 years if you full time rv. Just my opinion.
2015 Solera 24r
2017 Jeep Wrangler
05-13-2022, 05:59 AM
I had both my local tire guy (have used him for over 30 years) and MB Sprinter Service manager (just got it serviced) tell me not to rotate as in previous post.
Les & Heidi Kramer
2021 Jayco Melbourne 24L
Olmsted Township, OH
05-13-2022, 10:16 AM
I don't rotate other than fronts from side to side. Just replaced my tires that had 62,000 miles and plenty of tread. Replaced for age not wear.
2014 Solera 24R
USN Retired
05-13-2022, 10:47 AM
This is what I would do, but also the backs side to side, as well. Is there a reason you do not do the backs?
2023 Dynamax Force 34KD
-Demco Air Force One
2005 Toyota Tacoma 4x2 Crew Cab
-Remco 2pc Drive Shaft w/Disconnect
-Blue-Ox Avail Tow Bar and Baseplate
05-13-2022, 12:56 PM
Originally Posted by Art Peterson
>snip> Also, is there anywhere I can find a detailed list of what and when to do service like you would see and a car owners manual. Forest River, Dynamax and Mercedes national customer service centers all say the local tech's will tell me what is required. Just doesn't sound right. Thanks
Search on Sprinter A and B service.
Mike and JoAnne
Montana Summer / Arizona Winter
2016 Prism 24G /2002 HitchHiker 38LKTG
ACME EZTowing a 2015 Chevy Sonic RS Hatchback
05-13-2022, 04:16 PM
Rears wear evenly so I don't see the need. Probably wouldn't hurt, but I don't rotate them.
2014 Solera 24R
USN Retired
05-13-2022, 04:22 PM
The owners maintenance manual gives a fairly good list of required items. Most are checking general condition of the vehicle. Oil change, brake fluid, trans fluid, fuel filter, etc.
2014 Solera 24R
USN Retired
05-14-2022, 01:54 PM
Tire rotation is recommended to prevent wear or if wear is present to even it out as much as possible to extend tire life.
With Dual Wheel applications the inner and outer tire need to be as closely matched as possible. With large truck tires this involved actually checking the circumference of each mounted and inflated tire and "pairing" those with as closely matched circumferences as possible.
With Duall Wheel/Tire applications it's really a case of "of it's not broken, don't fix it". Even wear is hard to improve on.
Put the extra effort and money into more regular front wheel alignment checks.
05-16-2022, 05:08 PM
X2. Having discussed with local MB Service center they don't recommend any rotation unless unusual wear is shown from mis-alignment. At most rotating the fronts might need to be made but truth be told unless your Sprinter is driven like a car normal wear and tear for a MH; tire wear is done on visual and normally from old tire age making most decisions needed.
Retired Army CWO//DoD Army Civilian//2018 Dynamax Isata 3 24FW, Apr 13 2018
