Boy, I think I've really messed up. I'm starting here in case the subject outlet is unique to the 2401WS or similar and will move to another electrical forum if moderators think appropriate.
I misjudged a turn into a parking space and struck an adjacent truck with the exterior outlet cover on my 2017 2401WS MBS. The impact pretty much ripped the outlet cover off flush with the body (and damaged one hinge on the propane access door but it still functions).
Before removing the outlet I purchased another, much more elegant and with a lower profile cover.
I do a bit of electrical work around the house but I wasn't prepared for what I found under the damaged outlet. Pictures should follow.
There were two lines of Romex-type wire, black, white and ground in each entering the outlet from the rear of the rig and a single line towards the front of the rig, a total of nine wires, 6 from the rear and 2 from the front, wedged into V-shaped connectors
There was a cover over the wiring on the back damaged outlet that I pried loose. In the process three wires (black, white and ground) came loose from outlet. It appears that the wires were simply laid into the V-shaped connectors and that installing the plastic cover wedged them down to make contact. No wires were stripped back.
I searched RS, the only identifier on the damaged outlet but can't find anything like it.
The replacement outlet has a single ground and two connecting screws on each side.
My rig's winterized so I'm not in any rush to get this fixed. If need be I'll cap all the wires before removing the batteries for the winter.
Probably TMI and verbose but any guidance would be much appreciated
https://fasteddie.smugmug.com/RV-Ele...utlet/n-tgSZKr
