Old 09-01-2020, 10:12 PM   #1
Forester 2401w low point drain cap leaking
I noticed after filling the fresh water tank and turning on the pump that the water heater low point drain cap was leaking. I tried fixing it with Teflon tape on the threads but couldn’t fully stop the leak. Anyone else have this issue and how did you fix it? Thanks.
Cortes240 is offline   Reply With Quote
Old 09-02-2020, 05:41 AM   #2
Make sure your rubber seal is in place, Lowe’s have them if they need to be replaced
lwalkplumb is offline   Reply With Quote
Old 09-02-2020, 05:45 AM   #3
YEP. need to see if the rubber seal is still inside the cap. Other option is get rid of the CAPS and replace with 1/4 turn valve.
TheWolfPaq82 is offline   Reply With Quote
Old 09-02-2020, 06:57 AM   #4
To eliminate potential leaks from the cap, and eliminate having to crawl under the motorhome to drain the line, I installed a 1/4 turn PEX valve in the compartment right above where the drain tube exits. I don’t know how the plumbing is routed in your particular motorhome, but you might consider installing a valve.
2020 Sunseeker 2440DS Ford, Trekker cap, Topaz paint
BehindBars is offline   Reply With Quote
Old 09-02-2020, 08:43 AM   #5
Ok well that’s the issue as there is no rubber seal. Thanks! Is it a rubber washer or an o-ring?
Old 09-02-2020, 08:47 AM   #6
This is a good idea. It seems like the caps hanging down are just looking for trouble.
Old 09-02-2020, 09:21 AM   #7
Head Rambler
Mine had rubber cone washers in them before I changed them out to ¼ turn valves.
They looked like this.
Gotta go campin!
Old 09-02-2020, 01:29 PM   #8
You could take the cap into a hardware store to get an o ring or washer to fit. I cut a rubber disk from an inner tube to fit inside the cap.
Glampen is offline   Reply With Quote
Old 09-02-2020, 01:34 PM   #9
Thanks everyone for all the great suggestions. I verified that the gasket was missing in the cap and will see if my local hardware store has something that will work to replace it otherwise it’s on to Lowe’s or HD.
Old 09-02-2020, 01:39 PM   #10
Take one of the other caps with you to the hardware store. FYI
shadows4 is offline   Reply With Quote
Old 09-02-2020, 01:46 PM   #11
Yes, good idea. Thanks.
Old 09-05-2020, 09:13 AM   #12
TowPro's Avatar
You can cut them off and replace with ball valve that has built in shark bite fitting.
2019 Forest River Forester MBS 2401R
TowPro is offline   Reply With Quote
Old 09-05-2020, 06:56 PM   #13
Thanks for the suggestion. I ended up fixing the leak with a cone washer and have since found replacement caps at Ace hardware so for now the problem is solved. I do plan on replacing these fittings with proper valves when I get a chance.
drain, forester, leak
