Measure across the flat sides or the cap, it should be 84mm, that way I will be sure to lead to the correct one. One thing about changing the oil on those is to remove the filter before draining the oil, otherwise old oil will remain in the filter housing then run down into the oil pan you just drained when you remove the filter. I have been servicing those for years, and still do on a limited basis in my Home retirement shop.
